Home » Language IDEs » Java Development Tools (JDT) » Running an Eclipse Application from within Ant(OSGI Eclipse Application Dispatch)
Running an Eclipse Application from within Ant [message #1844123] Wed, 01 September 2021 21:00 Go to next message
There are a number of functionalities, especially in the model-driven area that use Eclipse Applications for dispatch.
Provided that an ant build is executed in the same JRE as the Eclipse instance, is there a recommended way to launch an application from within ant.
I guess I am looking for the Eclipse-internal equivalent of the Java execution task in ant.
Re: Running an Eclipse Application from within Ant [message #1844170 is a reply to message #1844123] Sat, 04 September 2021 02:30 Go to previous message
While Ant support is technically available within Eclipse, I found that the very poor debugging experience particularly in regard to the 'taskpath' meant that just about any other approach was better. Personally I use MWE2 for all such 'scripting' since I can write MWE2 tasks and debug them pretty much just like direct Java.
This realisation discourages me and I suspect others from supporting, let alone improving, Ant access. I don't think I've actually removed any Ant tasks, but I always sigh whenever a releng breakage occurs and wonder whether it really is worth the non-trivial maintenance time in consideration to the close to zero usage. QVTo and EMF have Ant support that must be considered at risk. I strongly recommend that you reconsider your use of Ant.
Ed Willink
[Updated on: Sat, 04 September 2021 02:31] by Moderator
Previous Topic:Internal errors when running WildFly in Eclipse 2021-06
Next Topic:Eclipse freezes whenever I try to edit a Java file.
Current Time: Sat Jul 26 03:13:20 EDT 2025
Powered by FUDForum. Page generated in 0.03338 seconds
