Home » Newcomers » Newcomers » FrameworkEvent ERROR
FrameworkEvent ERROR [message #1775718] Fri, 03 November 2017 18:19 Go to next message
!SESSION 2017-11-03 18:16:54.189 -----------------------------------------------
eclipse.buildId=M20130204-1200
java.version=9.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2017-11-03 18:16:55.283
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612 [1]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2017-11-03 18:16:55.299
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612.jar was not resolved.
!ENTRY org.eclipse.osgi 2 0 2017-11-03 18:16:55.330
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-11-03 18:16:55.330
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2017-11-03 18:16:55.330
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.1))(&(osgi.ee=JavaSE)(version=1.4)))".
!ENTRY org.eclipse.osgi 2 0 2017-11-03 18:16:55.346
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-11-03 18:16:55.346
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.301.v20120914-163612 [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2017-11-03 18:16:55.346
!ENTRY org.eclipse.osgi 4 0 2017-11-03 18:16:55.377
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Re: FrameworkEvent ERROR [message #1775726 is a reply to message #1775718] Sat, 04 November 2017 01:43 Go to previous messageGo to next message
You're trying to use Java 9 with a version of Eclipse that is over 4 years old. Oxygen.1a is the first release of Eclipse that is ready to run specifically under Java 9, and it's also the supported release. If you must use an older, unsupported, release, check the Wiki page at https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 for instructions on adding the right startup parameters to your eclipse.ini file, script, or shortcut.
Re: FrameworkEvent ERROR [message #1775727 is a reply to message #1775726] Sat, 04 November 2017 02:56 Go to previous messageGo to next message
I need IDE For Java Developers.
Re: FrameworkEvent ERROR [message #1775729 is a reply to message #1775727] Sat, 04 November 2017 04:10 Go to previous messageGo to next message
Get the Oxygen version of that from https://www.eclipse.org/downloads/
Re: FrameworkEvent ERROR [message #1843546 is a reply to message #1775729] Thu, 05 August 2021 09:14 Go to previous messageGo to next message
My successfull try was after having the same error when on startup of the specific eclipse ide. is to delete the eclipse.ini file in the main folder.
I think the .ini file was somehow changed and corrupted. So eclipse will startup without the eclipse.ini. I could start it without the exception.
Re: FrameworkEvent ERROR [message #1843990 is a reply to message #1843546] Thu, 26 August 2021 04:50 Go to previous message
[2021-08-26 08:49:34.634 Z] [Start Level: Equinox Container: a01b5489-4a06-001c-1df0-bc03e33ee072] INFO org.eclipse.orion.server.config - Started Orion server authentication successfully.
!ENTRY org.eclipse.orion.server.git 4 0 2021-08-26 11:49:34.650
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.orion.server.git [71]
Unresolved requirement: Require-Bundle: org.eclipse.jgit; bundle-version="3.4.0"
-> Bundle-SymbolicName: org.eclipse.jgit; bundle-version="4.4.0.201606070830-r"
org.eclipse.jgit [56]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.7))"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
[2021-08-26 08:49:34.666 Z] [Worker-0] INFO org.eclipse.orion.server.config - No server configuration file found at: C:\Users\Tsikhanavets_A\Downloads\eclipse-orion-22.0.0S1-win32.win32.x86_64\eclipse\orion.conf
[2021-08-26 08:49:34.667 Z] [Worker-0] INFO org.eclipse.orion.server.config - No server configuration file found at: C:\Users\Tsikhanavets_A\Downloads\eclipse-orion-22.0.0S1-win32.win32.x86_64\eclipse\serverworkspace\orion.conf
[2021-08-26 08:49:34.685 Z] [Worker-0] INFO org.eclipse.orion.server.config - Loaded simple metadata store (version 8).
[2021-08-26 08:49:34.688 Z] [Worker-0] INFO org.eclipse.orion.server.config - Tasks metadata location is C:\Users\Tsikhanavets_A\Downloads\eclipse-orion-22.0.0S1-win32.win32.x86_64\eclipse\serverworkspace\.metadata\.tasks
[2021-08-26 08:49:34.690 Z] [Worker-0] INFO org.eclipse.orion.server.config - Started Orion server core successfully.
[2021-08-26 08:49:34.736 Z] [Worker-0] INFO org.eclipse.orion.server.config - Finished processing 1 users for registerUserProperties, duration: 46ms
osgi>
Previous Topic:Clean install 2019-12 won't update
Next Topic:XML tools install from 2020-06 J10 repo uses 2021 J11 WST XML core
Current Time: Mon Jul 21 07:27:24 EDT 2025
Powered by FUDForum. Page generated in 0.17176 seconds
