Home » Modeling » Papyrus » Incomplete import in Java generated code by Papyrus Designer(Papyrus Designer generates an incomplete import for derived classes)
Incomplete import in Java generated code by Papyrus Designer [message #1843871] Sun, 22 August 2021 17:33 Go to next message
I have a UML model in Papyrus with a set of signals within a package. These signals are organized into a hierarchy.
When I generate code, what I get for the signal at the root of the tree is correct, as below:
package com.elastskin.ppmweb.service.state.productionsignals.Signals;
public abstract class Prod_Signal {
public Instant pevttimestamp;
but the code for all descendants contains a line with an ill-formed import (missing the '*' at the end):
import com.elastskin.ppmweb.;
public abstract class Prod_PrintSystem_Signal extends Prod_Signal
Is it a bug? How can I work around it?
Versions:
Papyrus
Version: 2021-06 (4.20)
Build id: 2021-03-21T18:43:59Z
org.eclipse.papyrus.designer.languages.java.codegen (1.1.1.202103190948) "Papyrus Designer Java code generation" [Active]
org.eclipse.papyrus.designer.languages.java.library (1.1.1.202011271115) "Papyrus Designer Java library" [Starting]
org.eclipse.papyrus.designer.languages.java.profile (1.1.1.202011271115) "Papyrus Designer Java profile" [Active]
[Updated on: Sun, 22 August 2021 17:34] by Moderator
Re: Incomplete import in Java generated code by Papyrus Designer [message #1843875 is a reply to message #1843871] Mon, 23 August 2021 00:16 Go to previous messageGo to next message
I suspect that you are looking in the wrong direction. The Eclipse tooling that I use does not usually use "*" imports; rather all required imports are provided explicitly. If a "*" appears it comes from the Java prettifier. Perhaps the target of a missing import is not accessible.
Ed Willink
Re: Incomplete import in Java generated code by Papyrus Designer [message #1843887 is a reply to message #1843875] Mon, 23 August 2021 07:22 Go to previous messageGo to next message
Thanks for your response, Ed.
When you say "Eclipse tool" do you mean a Java IDE or Eclipse Papyrus? My problem is with the Papyrus code generator and not with the Java IDE.
I was expecting Papyrus to generate the explicit imports for each dependency, as you said, but that is not what is happening.
Re: Incomplete import in Java generated code by Papyrus Designer [message #1843904 is a reply to message #1843887] Mon, 23 August 2021 13:06 Go to previous messageGo to next message
I'm mostly referring to EMF and my own OCL CG based on EMF. When I don't like what I see I go in with a debugger and as often as not discover that the problem is my inadequate configuration, perhaps based on the need to use a poorly documented facility. Sometimes it is necessary to create a tool customization that may perhaps need contributing back a s a fix.
Ed Willink
Re: Incomplete import in Java generated code by Papyrus Designer [message #1843907 is a reply to message #1843904] Mon, 23 August 2021 19:49 Go to previous messageGo to next message
I've just found out that in a previous version of my Papyrus project, this problem does not happen and Papyrus generates all Java imports beautifully.
I am trying to figure out what have I changed in the project that causes the problem.
If I find it might be a bug, I will report it to the appropriate channel. Going further than that is beyond my possibilities because I don´t have the expertise and time to venture into changing Eclipse.
Thanks for your comments, Ed.
Re: Incomplete import in Java generated code by Papyrus Designer [message #1844073 is a reply to message #1843907] Tue, 31 August 2021 04:21 Go to previous message
I can reproduce the issue. Thanks for reporting.
Previous Topic:Cannot install Papyrus-Update-5.2.0I2.zip on 2021-06 - missing XWT
Next Topic:What is the meaning of each element in the *.notation file
Current Time: Mon Jul 21 11:28:43 EDT 2025
Powered by FUDForum. Page generated in 0.20782 seconds
