Home » Modeling » M2T (model-to-text transformation) » How to access imported packages(Acceleo Papyrus)
How to access imported packages [message #1843727] Mon, 16 August 2021 04:42 Go to next message
How to access packages imported via UML::PackageImport and the elements within the imported packages with Acceleo?
/Carsten
[Updated on: Mon, 16 August 2021 04:44] by Moderator
Re: How to access imported packages [message #1843763 is a reply to message #1843727] Tue, 17 August 2021 02:51 Go to previous messageGo to next message
I don't see the problem. Just do it.
If you share your best (failing) endeavor, it may be easier to help.
Ed Willink
Re: How to access imported packages [message #1843767 is a reply to message #1843763] Tue, 17 August 2021 04:18 Go to previous message
Hi Ed,
indeed, it was a mere layer 8 problem. I simply mixed up logical (semantic) ownership with model element ownership.
Many thanks Ed, for your "Just do it." statement, which hinted me to the root cause.
/Carsten
Previous Topic:Passing a Type as parameter in acceleo always results in AnyType
Next Topic:From Ecore to Java
Current Time: Wed Jul 30 08:35:47 EDT 2025
Powered by FUDForum. Page generated in 0.03536 seconds
