Home » Language IDEs » Java Development Tools (JDT) » Error in .metadata\.log
Error in .metadata\.log [message #1843759] Tue, 17 August 2021 00:54 Go to next message
!SESSION 2021-07-16 11:00:00.807 -----------------------------------------------
eclipse.buildId=4.20.0.I20210611-1600
java.version=16.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.jface 2 0 2021-07-16 11:00:25.776
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-16 11:00:25.776
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
Open a type in a Java editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@a1cb94,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
Category(org.eclipse.lsp4e.category,Language Servers,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@46d148bd,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-16 11:01:18.101
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\ABINANDAN'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
!SESSION 2021-07-17 11:05:35.029 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-17 11:08:48.606
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-17 11:08:48.606
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@4ed19b69,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@59a5bb61,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-17 11:09:10.803
!SESSION 2021-07-17 11:18:36.913 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-17 11:18:45.061
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-17 11:18:45.061
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@749f61a3,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@36d7a68a,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-17 11:18:52.642
!SESSION 2021-07-17 11:54:28.506 -----------------------------------------------
java.version=16.0.1
Command-line arguments: -data file:/C:/Users/ABINANDAN/eclipse-workspace/ -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.jface 2 0 2021-07-17 11:54:33.433
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-17 11:54:33.433
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2493eec6,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@42d174ad,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-17 11:54:43.633
!SESSION 2021-07-17 13:08:17.801 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-17 13:08:23.470
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-17 13:08:23.470
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@173a5fad,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@2ce47652,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-17 13:08:39.023
!ENTRY org.eclipse.eclemma.core 4 5013 2021-07-17 18:52:39.367
!MESSAGE Error while dumping coverage data (code 5013).
!STACK 0
java.net.SocketException: Connection reset
at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:323)
at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:350)
at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:803)
at java.base/java.net.Socket$SocketInputStream.read(Socket.java:976)
at java.base/java.net.Socket$SocketInputStream.read(Socket.java:971)
at java.base/java.io.FilterInputStream.read(FilterInputStream.java:82)
at org.jacoco.core.data.ExecutionDataReader.read(ExecutionDataReader.java:84)
at org.eclipse.eclemma.internal.core.MemoryExecutionDataSource.readFrom(MemoryExecutionDataSource.java:69)
at org.eclipse.eclemma.internal.core.launching.AgentServer.run(AgentServer.java:115)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!SESSION 2021-07-18 08:30:14.354 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-18 08:30:45.107
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-18 08:30:45.107
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@35b3c1f6,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@495da9a7,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-18 08:31:15.844
!SESSION 2021-07-19 09:02:36.750 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-19 09:03:36.623
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-19 09:03:36.623
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7742a276,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@1f48fa72,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-19 09:04:13.387
!SESSION 2021-07-22 15:25:34.633 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-22 15:26:16.198
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-22 15:26:16.198
,,true),null),
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-22 15:27:01.334
!SESSION 2021-07-23 08:51:33.087 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-23 08:51:50.742
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-23 08:51:50.742
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@4db6348b,
,,true),null),
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-23 08:52:18.244
!SESSION 2021-07-23 15:36:09.595 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-23 15:36:20.246
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-23 15:36:20.246
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@3ba97962,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@35becbd4,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-23 15:36:53.533
!SESSION 2021-07-25 10:02:51.509 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-25 10:03:08.177
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-25 10:03:08.178
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@732d078d,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@58bad46f,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-25 10:04:07.736
!SESSION 2021-07-25 11:43:02.582 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.core.resources 2 10035 2021-07-25 11:43:05.508
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 2 0 2021-07-25 11:43:10.684
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-25 11:43:10.684
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@b808af5,
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@18b04526,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-25 11:43:47.375
!SESSION 2021-07-25 17:47:26.606 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-25 17:47:34.095
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-25 17:47:34.096
,,true),null),
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-25 17:47:55.497
!SESSION 2021-07-26 09:06:03.332 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-26 09:06:08.270
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-26 09:06:08.270
,,true),null),
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-26 09:06:42.079
!ENTRY org.eclipse.jdt.core 4 4 2021-07-26 11:04:12.908
!MESSAGE Exception occurred during compilation unit conversion:
----------------------------------- SOURCE BEGIN -------------------------------------
package demos;
import java.util.HashMap;
import java.util.List;
import java.util.Map;
import de.fhpotsdam.unfolding.UnfoldingMap;
import de.fhpotsdam.unfolding.data.Feature;
import de.fhpotsdam.unfolding.data.GeoJSONReader;
import de.fhpotsdam.unfolding.geo.Location;
import de.fhpotsdam.unfolding.marker.Marker;
import de.fhpotsdam.unfolding.providers.*;
import de.fhpotsdam.unfolding.providers.Microsoft;
import de.fhpotsdam.unfolding.utils.MapUtils;
import processing.core.PApplet;
public class LiteracyRatesWorld extends PApplet{
UnfoldingMap map;
Map<String, Float> literacyRatesByCountries;
List<Feature> countries;
List<Marker> countriesMarkers;
int[] color=
public void setup() {
size(1500, 1500, OPENGL);
map = new UnfoldingMap(this, 0, 0, 1500, 1500, new Microsoft.RoadProvider());
// MapUtils.createDefaultEventDispatcher(this, map);
// Load lifeExpectancy data
literacyRatesByCountries = loadliteracyRatesByStates("cross-country-literacy-rates.csv");
println("Loaded " + literacyRatesByCountries.size() + " data entries");
// Load country polygons and adds them as markers
countries = GeoJSONReader.loadData(this, "countries.geo.json");
// countries = GeoJSONReader.loadData(this, ARGS_BGCOLOR)
countriesMarkers = MapUtils.createSimpleMarkers(countries);
// map.zoomAndPanTo(new Location(52.5f, 13.4f), 10);
map.addMarkers(countriesMarkers);
shadeCountries();
// Country markers are shaded according to life expectancy (only once)
private void shadeCountries() {
for (Marker marker : countriesMarkers) {
// Find data for country of the current marker
String countryId = marker.getId();
if (literacyRatesByCountries.containsKey(countryId)) {
float lifeExp = literacyRatesByCountries.get(countryId);
// Encode value as brightness (values range: 40-90)
int colorLevel = (int) map(lifeExp, 40, 90, 10, 255);
int color = color(255-colorLevel, 100, colorLevel);
marker.setColor(color);
else {
marker.setColor(color(150,150,150));
private Map<String, Float> loadliteracyRatesByStates(String string) {
// TODO Auto-generated method stub
Map<String,Float> literacyRatesMap=new HashMap<String,Float>();
String[] rows=loadStrings(string);
for(String row:rows) {
System.out.println(row);
String[] columns=row.split(",");
if(columns.length==4 && columns[2].equals("2015")) {
System.out.println(columns[3]);
literacyRatesMap.put(columns[1], Float.parseFloat(columns[3]));
else if(columns[2].equals("2003") && Float.parseFloat(columns[3])>96) {
return literacyRatesMap;
public void draw() {
map.draw();
----------------------------------- SOURCE END -------------------------------------
!STACK 0
java.lang.IllegalArgumentException
at org.eclipse.jdt.core.dom.ASTNode.setSourceRange(ASTNode.java:3189)
at org.eclipse.jdt.core.dom.ASTConverter.convertToFieldDeclaration(ASTConverter.java:3661)
at org.eclipse.jdt.core.dom.ASTConverter.checkAndAddMultipleFieldDeclaration(ASTConverter.java:541)
at org.eclipse.jdt.core.dom.ASTConverter.buildBodyDeclarations(ASTConverter.java:201)
at org.eclipse.jdt.core.dom.ASTConverter.convert(ASTConverter.java:3347)
at org.eclipse.jdt.core.dom.ASTConverter.convert(ASTConverter.java:1524)
at org.eclipse.jdt.core.dom.AST.convertCompilationUnit(AST.java:494)
at org.eclipse.jdt.internal.core.CompilationUnit.buildStructure(CompilationUnit.java:201)
at org.eclipse.jdt.internal.core.Openable.generateInfos(Openable.java:266)
at org.eclipse.jdt.internal.core.JavaElement.openWhenClosed(JavaElement.java:597)
at org.eclipse.jdt.internal.core.CompilationUnit.makeConsistent(CompilationUnit.java:1142)
at org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation.makeConsistent(ReconcileWorkingCopyOperation.java:173)
at org.eclipse.jdt.internal.core.ReconcileWorkingCopyOperation.executeOperation(ReconcileWorkingCopyOperation.java:94)
at org.eclipse.jdt.internal.core.JavaModelOperation.run(JavaModelOperation.java:740)
at org.eclipse.jdt.internal.core.JavaModelOperation.runOperation(JavaModelOperation.java:806)
at org.eclipse.jdt.internal.core.CompilationUnit.reconcile(CompilationUnit.java:1319)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.reconcile(JavaReconcilingStrategy.java:131)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.access$0(JavaReconcilingStrategy.java:113)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy$1.run(JavaReconcilingStrategy.java:93)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.reconcile(JavaReconcilingStrategy.java:90)
at org.eclipse.jdt.internal.ui.text.java.JavaReconcilingStrategy.reconcile(JavaReconcilingStrategy.java:157)
at org.eclipse.jdt.internal.ui.text.CompositeReconcilingStrategy.reconcile(CompositeReconcilingStrategy.java:94)
at org.eclipse.jdt.internal.ui.text.JavaCompositeReconcilingStrategy.reconcile(JavaCompositeReconcilingStrategy.java:107)
at org.eclipse.jface.text.reconciler.MonoReconciler.process(MonoReconciler.java:76)
at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:210)
!ENTRY org.eclipse.jdt.ui 4 2 2021-07-26 11:04:12.912
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jdt.ui".
!STACK 0
!ENTRY org.eclipse.jdt.ui 4 0 2021-07-26 11:04:12.913
!MESSAGE Error in JDT Core during reconcile
!STACK 0
!ENTRY org.eclipse.jdt.core 4 4 2021-07-26 11:04:20.428
package demos;
UnfoldingMap map;
int[] colors=
shadeCountries();
else {
map.draw();
!STACK 0
!ENTRY org.eclipse.jdt.ui 4 2 2021-07-26 11:04:20.429
!STACK 0
!ENTRY org.eclipse.jdt.ui 4 0 2021-07-26 11:04:20.429
!STACK 0
!SESSION 2021-07-29 14:43:02.172 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-29 14:43:06.134
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-29 14:43:06.134
,,true),null),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@7c0e4e4e,
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-29 14:43:25.213
!SESSION 2021-07-29 15:03:05.967 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.jface 2 0 2021-07-29 15:03:14.928
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-29 15:03:14.928
,,true),null),
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2021-07-29 15:03:27.101
!SESSION 2021-07-30 09:59:30.826 -----------------------------------------------
java.version=16.0.1
!ENTRY org.eclipse.core.resources 2 10035 2021-07-30 10:00:41.663
!ENTRY org.eclipse.jface 2 0 2021-07-30 10:01:01.099
!SUBENTRY 1 org.eclipse.jface 2 0 2021-07-30 10:01:01.099
,,true),null),
org.ecli
Re: Error in .metadata\.log [message #1843877 is a reply to message #1843759] Mon, 23 August 2021 02:39 Go to previous message
I see a bunch of IllegalArgumentException in the log. If you think this is affecting the behavior of the IDE/editor in some way, please report a bug against jdt/core.
Previous Topic:JDK 10.0.1, Unable to add JRE
Next Topic:How about Adding a "Create a Gist" option to the IDE
Current Time: Sun Jul 27 12:02:43 EDT 2025
Powered by FUDForum. Page generated in 0.05198 seconds
