Home » Modeling » M2T (model-to-text transformation) » Passing a Type as parameter in acceleo always results in AnyType
Passing a Type as parameter in acceleo always results in AnyType [message #1843459] Fri, 30 July 2021 10:07 Go to next message
I want to pass a Type to a query.
However, whenever I try:
[query public Test(T : OclType) : String = T.toString()/]
I get:
org.eclipse.ocl.ecore.impl.AnyTypeImpl@12dbef96 (name: T) (instanceClassName: null)
.toString() directly at the type gives me the expected result, e.g.:
org.eclipse.emf.ecore.impl.EClassImpl@1f799f4c (name: TechnicalFunction) (instanceClassName: null) (abstract: false, interface: false)
Version:
index.php/fa/40819/0/
  • Attachment: Unbenannt.JPG
    (Size: 25.27KB, Downloaded 299 times)
[Updated on: Fri, 30 July 2021 10:08] by Moderator
Re: Passing a Type as parameter in acceleo always results in AnyType [message #1843461 is a reply to message #1843459] Fri, 30 July 2021 10:32 Go to previous messageGo to next message
solved: T is a keyword...
Re: Passing a Type as parameter in acceleo always results in AnyType [message #1843463 is a reply to message #1843461] Fri, 30 July 2021 14:28 Go to previous messageGo to next message
Well diagnosed. But not quite right.
"T" is not a reserved or restricted word in OCL 2.4. Rather "T" is some magic that looks remarkably like a template parameter without the inconvenience of following through on alignment with UML and its template capabilities.
Acceleo uses the Classic Eclipse OCL in which "T" and "T1" magic are realized as reserved words.
The newer Pivot-based Eclipse OCL supports UML-like templates and so "T" is only captured within scopes in which"T" has been declared as a template parameter.
Ed Willink
Re: Passing a Type as parameter in acceleo always results in AnyType [message #1843464 is a reply to message #1843463] Fri, 30 July 2021 16:22 Go to previous messageGo to next message
Hi Ed,
thanks for the insight!
Yeah, I tried to use the passed type as kind of template parameter, e.g.:
[query public Test(any : OclAny, tpe : OclType) : OrderedSet(tpe ) = any.eInverse(tpe )/]
However, it seems like the signature cannot contain "template" parameters (though I could simply use a common base-class) and also OCL is not happy about variable types.
The query I want to write will only use 3 types, I can check for the passed type with if-statements and have static typed queries or is there another way? For now I have 3 times the same query with different types, which is not too elegant I think.
[Updated on: Fri, 30 July 2021 18:42] by Moderator
Re: Passing a Type as parameter in acceleo always results in AnyType [message #1843466 is a reply to message #1843464] Sat, 31 July 2021 02:16 Go to previous message
Yeah. That's why we need templates.
The OMG specification states that OCL is UML-aligned, giving a very strong indication that OCL should support templates, but there is zero syntactical support for them. It is hardly surprising that Acceleo/MOFM2T and QVTo that extend OCL also lack template support. Eclipse QVTr has a template extension.
You might just get away with redirecting to OCLinEcore where templates are supported. The syntax was challenging; we all expect <> for templates but this conflicts with arithmetic operators and so requires parsing heroics (see my C++ PhD). OCL through Set(MyClass) already has () for templates so I ended up supporting <> for declarations and () for instantiations.
Ed Willink
Previous Topic:get the instance of the Main AcceleoGenerator class from query invoke
Next Topic:How to access imported packages
Current Time: Mon Jul 21 11:10:38 EDT 2025
Powered by FUDForum. Page generated in 0.23537 seconds
