Home » Modeling » TMF (Xtext) » Using LocalDateTime in Xtext Grammar
Using LocalDateTime in Xtext Grammar [message #1843217] Tue, 20 July 2021 08:48 Go to next message
Hello together,
can someone tell me how to use LocalDateTime in Xtext?
I defined this in xcore and convert it to Xtext dsl
class Event{
	String ^id
	String title
	String summary
	String location
    String description
	LocalDateTime start
	LocalDateTime end
	LocalDateTime created
	LocalDateTime lastModified
	String status
	String source
type LocalDateTime wraps LocalDateTime
create{
	LocalDateTime.parse(it, DateTimeFormatter.ofPattern("yyyy-MM-dd HH:mm:ss"))
}convert{
	if( it !== null ) DateTimeFormatter.ofPattern("yyyy-MM-dd HH:mm:ss").format(it)
The result looks likethis
[Event returns Event:
	{Event}
	'Event' '('
		('start' start=LocalDateTime)?
		('end' end=LocalDateTime)?
		('title' title=EString)?
		('location' location=EString)?
EIntegerObject returns ecore::EIntegerObject:
	'-'? INT;
LocalDateTime returns LocalDateTime:
	'LocalDateTime' /* TODO: implement this rule and an appropriate IValueConverter */;
How can I fill my LocalDateTime as String in the dsl and after that convert it to LocalDateTime?
How should I use the IValueConverter?
Best regards
Dimg
[Updated on: Tue, 20 July 2021 08:49] by Moderator
Re: Using LocalDateTime in Xtext Grammar [message #1843218 is a reply to message #1843217] Tue, 20 July 2021 08:52 Go to previous messageGo to next message
yes you should implement an IValueConverter.
the first question i did not understand.
maybe something like
LocalDateTime:
INT "-" INT "-" INT INT ":"INT;
and then make sure the stuff is correct in value converter
[Updated on: Tue, 20 July 2021 08:58] by Moderator
Re: Using LocalDateTime in Xtext Grammar [message #1843219 is a reply to message #1843218] Tue, 20 July 2021 09:23 Go to previous messageGo to next message
Thank you, yes I ask for the LocalDateTime pattern.
Where should I initialized the implemented ValueConverter?
Currently I use this grammar to generate the xmi file. At which point should I use the IValueConverter then?
Re: Using LocalDateTime in Xtext Grammar [message #1843220 is a reply to message #1843219] Tue, 20 July 2021 09:34 Go to previous messageGo to next message
subclass and bind DefaultTerminalConverters
Re: Using LocalDateTime in Xtext Grammar [message #1843222 is a reply to message #1843219] Tue, 20 July 2021 10:51 Go to previous message
Thank you I found it, the point is I have to bind the subclass of DefaultTerminalConverters to the RuntimeModule. It works!
Previous Topic:XtextDocument/Node does not update offset ?
Next Topic:Deadlock between Job and event listener on Display thread
Current Time: Mon Jul 21 03:35:32 EDT 2025
Powered by FUDForum. Page generated in 0.14274 seconds
