Home » Eclipse Projects » Sirius » Problem after installing Acceleo
Problem after installing Acceleo [message #1843185] Mon, 19 July 2021 09:21 Go to next message
I had working project using Sirius. After I installed Acceleo 3.7 from marketplace I got problem during running app. Now even if I unistall it problem is still occuring. I am pretty new and I have no idea how to fix it.
Console log:
!ENTRY org.eclipse.sirius.common.acceleo.mtl 4 0 2021-07-19 15:07:54.377
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.sirius.common.acceleo.mtl [531]
Bundle was not resolved because of a uses constraint violation.
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.sirius.common.acceleo.mtl [osgi.identity; osgi.identity="org.eclipse.sirius.common.acceleo.mtl"; type="osgi.bundle"; version:Version="6.1.3.201905061019"; singleton:="true"] because it is exposed to package 'com.google.common.base' from resources com.google.guava [osgi.identity; osgi.identity="com.google.guava"; type="osgi.bundle"; version:Version="21.0.0.v20170206-1425"] and com.google.guava [osgi.identity; osgi.identity="com.google.guava"; type="osgi.bundle"; version:Version="27.1.0.v20190517-1946"] via two dependency chains.
Chain 1:
require: (&(osgi.wiring.bundle=com.google.guava)(&(bundle-version>=15.0.0)(!(bundle-version>=22.0.0))))
provide: osgi.wiring.bundle: com.google.guava
Chain 2:
require: (&(osgi.wiring.bundle=org.eclipse.acceleo.engine)(bundle-version>=3.4.1))
provide: osgi.wiring.bundle; bundle-version:Version="3.7.11.202102190929"; osgi.wiring.bundle="org.eclipse.acceleo.engine"; singleton:="true"
org.eclipse.acceleo.engine [osgi.identity; osgi.identity="org.eclipse.acceleo.engine"; type="osgi.bundle"; version:Version="3.7.11.202102190929"; singleton:="true"]
import: (&(osgi.wiring.package=com.google.common.collect)(&(version>=27.0.0)(!(version>=30.2.0))))
export: osgi.wiring.package: com.google.common.collect; uses:=com.google.common.base
export: osgi.wiring.package=com.google.common.base
at org.eclipse.osgi.container.Module.start(Module.java:463)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1845)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1838)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1779)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1743)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1665)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.sirius.common.acceleo.mtl.ide 4 0 2021-07-19 15:07:54.381
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.sirius.common.acceleo.mtl.ide [532]
Unresolved requirement: Require-Bundle: org.eclipse.sirius.common.acceleo.mtl; bundle-version="2.0.0"
-> Bundle-SymbolicName: org.eclipse.sirius.common.acceleo.mtl; bundle-version="6.1.3.201905061019"; singleton:="true"
No resolution report for the bundle. Bundle was not resolved because of a uses constraint violation.
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.sirius.common.acceleo.mtl.ide [osgi.identity; osgi.identity="org.eclipse.sirius.common.acceleo.mtl.ide"; type="osgi.bundle"; version:Version="6.1.3.201905061019"; singleton:="true"] because it is exposed to package 'com.google.common.base' from resources com.google.guava [osgi.identity; osgi.identity="com.google.guava"; type="osgi.bundle"; version:Version="21.0.0.v20170206-1425"] and com.google.guava [osgi.identity; osgi.identity="com.google.guava"; type="osgi.bundle"; version:Version="27.1.0.v20190517-1946"] via two dependency chains.
Chain 1:
Chain 2:
require: (&(osgi.wiring.bundle=org.eclipse.acceleo.common)(bundle-version>=3.4.1))
provide: osgi.wiring.bundle; bundle-version:Version="3.7.11.202102190929"; osgi.wiring.bundle="org.eclipse.acceleo.common"; singleton:="true"
org.eclipse.acceleo.common [osgi.identity; osgi.identity="org.eclipse.acceleo.common"; type="osgi.bundle"; version:Version="3.7.11.202102190929"; singleton:="true"]
import: (&(osgi.wiring.package=com.google.common.base)(&(version>=27.0.0)(!(version>=30.2.0))))
export: osgi.wiring.package: com.google.common.base
15:08:07.352 [main] DEBUG org.eclipse.m2e.core.internal.project.registry.ProjectRegistryRefreshJob - Queued refresh request: [/cardGameModeling/pom.xml, /cardGameModeling.design/pom.xml]
15:08:11.534 [Worker-2: Loading available Gradle versions] INFO org.eclipse.buildship.core.internal.util.gradle.PublishedGradleVersions - Gradle version information cache is up-to-date. Trying to read.
Thanks in advance,
Jezierski Marcel
Re: Problem after installing Acceleo [message #1843195 is a reply to message #1843185] Mon, 19 July 2021 14:26 Go to previous messageGo to next message
Ar a quick glance it appears that Acceleo has not tracked the rapid changes in Guava versions and insists on mandating one that has been tested rather than allowing whatever is distributed.
Ed Willink
Re: Problem after installing Acceleo [message #1843197 is a reply to message #1843195] Mon, 19 July 2021 16:18 Go to previous message
Correction. You are using the latest Acceleo which expects Guava 27.0,
but a two year old Sirius that expects Huava 20.
Use consistent releases.
Ed Willink
Previous Topic:Creating sub-node problem.
Next Topic:Enable Graphical EMF Compare of Model
Current Time: Sun Jul 20 20:46:09 EDT 2025
Powered by FUDForum. Page generated in 0.03971 seconds
