Update Error (via Eclipse) [message #1842991] |
Thu, 08 July 2021 21:16  |
An error occurred while collecting items to be installed
session context was:(profile=C__Users_lucab_eclipse_java-2020-06_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.emf.edit.ui,2.20.0.v20210506-1232
Running on Windows 10, default install location. with Admin privileges.
Re: Update Error (via Eclipse) [message #1843115 is a reply to message #1842991] |
Fri, 16 July 2021 02:09  |
Sometimes that happens because there repository information is inconsistently loaded, i.e., a newer metadata repository information with older artifact repository information. Sometimes simply restarting will fix the problem. Using Window -> Preferences -> Oomph -> Bundle Pools -> Clear Cache... should clear the caches and also solve the problem.
FUDForum. Page generated in 0.06955 seconds
