Home » Newcomers » Newcomers » Eclipse with PyDev Console not updating(Import Selenium and Console doesn't update unless I click it)
Eclipse with PyDev Console not updating [message #1843086] Wed, 14 July 2021 19:49
I just installed Eclipse yesterday and can't figure this out. I'm using Python in Eclipse and have this simple program, which should log stuff to the console:
test_int = 0
for i in range(0, 10000):
    test_int += 1
print(str(test_int))
y = input("WTF?")
Which works fine. The problem is when I try to import Selenium and change the code to this
from selenium import webdriver
test_int = 0
    test_int += 1
y = input("WTF?")
Now when I run the same program, the console in Eclipse won't display the input until I click somewhere in the coding window after the program has started running. Then the console updates instantly.
I've attached a screenshot after the program has been running 10 seconds, and you can see the console hasnt updated. The second screenshot is after I click on the coding window, and the console updates.
Thanks for your help in fixing this.
  • Attachment: ecl1.png
    (Size: 102.94KB, Downloaded 96 times)
  • Attachment: ecl2.png
    (Size: 76.04KB, Downloaded 92 times)
Previous Topic:Getting compliance error while trying to export feature project from my eclipse rcp workspace
Next Topic:Encoding issue
Current Time: Sun Jul 20 22:57:16 EDT 2025
Powered by FUDForum. Page generated in 0.10177 seconds
