Home » Language IDEs » C / C++ IDE (CDT) » Errors while building CDT 3_1_1
Errors while building CDT 3_1_1 [message #184300] Fri, 09 February 2007 15:21 Go to next message
Originally posted by: Sami.Said.freescale.com
I’m getting these two Errors when I tried to build the CDT 3.1.1 using
org.eclipse.cdt-releng\org.eclipse.cdt.releng\build.xml file
I checked out the cdt_3.1.1 sources from CDT_3_1_1 tag
ERROR in
C:\cdt\org.eclipse.cdt-releng\org.eclipse.cdt.releng\results \plugins\org.eclipse.cdt.refactoring\src\org\eclipse\cdt\int ernal\refactoring\DocumentAdapter.java
(at line 141)
assert false;
Syntax error on token "assert", AssignmentOperator expected after this
token
ERROR in
C:\cdt\org.eclipse.cdt-releng\org.eclipse.cdt.releng\results \plugins\org.eclipse.cdt.refactoring\src\org\eclipse\cdt\int ernal\refactoring\UndoCTextFileChange.java
(at line 73)
assert buffer instanceof DocumentAdapter;
Syntax error on token "instanceof", = expected
Please help
Re: Errors while building CDT 3_1_1 [message #184311 is a reply to message #184300] Fri, 09 February 2007 16:19 Go to previous messageGo to next message
Sami wrote:
> I�m getting these two Errors when I tried to build the CDT 3.1.1 using
What version of Java are you using? Sounds like an issue with not
having 1.4.2...
Chris Recoskie
Team Lead, IBM CDT Team
IBM Toronto
http://www.eclipse.org/cdt
Re: Errors while building CDT 3_1_1 [message #184322 is a reply to message #184311] Fri, 09 February 2007 16:32 Go to previous message
Hi Chris,
I'm using Java 1.4.2_12, and i'm getting the same errors when using Java
1.5.0._08.
Sami
Previous Topic:How to add different make and gcc tools
Next Topic:Problems while moving from CDT 3.0.2 to CDT 3.1.1
Current Time: Sat Jul 19 00:52:39 EDT 2025
Powered by FUDForum. Page generated in 0.03553 seconds
