Home » Newcomers » Newcomers » Dependency injection with @inject(Dependency injection with @inject having problems)
Dependency injection with @inject [message #1842866] Sat, 03 July 2021 23:20 Go to next message
I currently have a pagination class, I will share it here:
package net;
public class PageClass {
    String pagination;
    public void setpagination(int maxPage, int cpage, String vfile, String queryvars, String pageName) {
        String pag = "<div class='pagination'>";
        int fpage = 1;
        int page = cpage;
        int limit = 3;
        int pageno = cpage;
        int spage = cpage;
        int lower = spage - 1;
        int upper = spage + 1;
        String self = vfile + "?";
        int khigh = 0;
        int klow = 0;
        if (maxPage > limit) {
            if (pageno > 1) {
                pag = pag + "<li><a href=" + self + pageName + "=" + fpage + queryvars + ">1..</a></li>";
                pag = pag + "<li><a href=" + self + pageName + "=" + (pageno - 1) + queryvars + ">&laquo; </a></li>";
            if (spage == 1) {
                klow = spage;
                khigh = limit;
            if (spage > 1) {
                if (lower < 1) {
                    klow = 1;
                    khigh = limit;
                } else {
                    klow = lower;
                    khigh = upper;
                if (upper > maxPage) {
                    khigh = maxPage;
                    klow = maxPage - (2 * 1);
            for (int i = klow; i <= khigh; i++) {
                if (i == pageno) {
                    pag = pag + "<li><span class='active'>" + i + "</span></li>";
                } else {
                    pag = pag + "<li><a href=" + self + pageName + "=" + i + queryvars + ">" + i + "</a></li>";
                    //pag = pag + "<li><a href=" + self + this->pag->pageName + "=" + i + queryvars + ">" + i + "</a></li>" + "\n";
            if (pageno < maxPage) {
                //pag = pag + "<span>...</span>";
                pag = pag + "<li><a href='" + self + pageName + "=" + (pageno + 1) + queryvars + "'>" + " &raquo;</a></li>";
                pag = pag + "<li><a href='" + self + pageName + "=" + (maxPage) + queryvars + "'>" + " .." + maxPage + "</a></li>";
        } else {
            /*     * * if this is page 1 there is no previous link ** */
            if (pageno != 1) {
                pag = pag + "<li><a href='" + self + pageName + "=" + (pageno - 1) + queryvars + "'>&laquo; </a></li>";
            /*     * * loop over the pages ** */
            for (int i = 1; i <= maxPage; i++) {
                if (i == pageno) {
                    pag = pag + "<li><span class='active'>" + i + "</span></li>" + "";
                } else {
                    pag = pag + "<li><a href='" + self + pageName + "=" + i + queryvars + "'>" + i + "  " + "</a></li>";
                }   //pag = pag + "<li><a href='" + self + pageName + "=" + i + queryvars + "'>" + i + "  " + "</a></li>" + "\n";
            /*     * * if we are on the last page, we do not need the NEXT link ** */
                pag = pag + "<li><a href='" + self + pageName + "=" + (pageno + 1) + queryvars + "'> &raquo; </a></li>";
                pag = pag + "<li><a href='" + self + pageName + "=" + maxPage + queryvars + "'> last </a></li>";
        pag = pag + "</div>";
        //String tmppag;
        if (maxPage < 2) {
            pag = "";
        this.pagination = pag;
    public String getpagination() {
        return (this.pagination);
It works great, but I have to load class like this:
net.PageClass paging = new net.PageClass();
I am trying to use @inject, I have placed all required things in servlet:
import jakarta.enterprise.context.RequestScoped;
import jakarta.inject.Inject;
and
@MultipartConfig
@WebServlet(
        name = "FindOwnerServlet",
        urlPatterns = {"/FindOwnerServlet"}
@RequestScoped
public class FindOwnerServlet extends HttpServlet {
    @Inject net.PageClass paging;
Usage is as follows:
            String vfile = "FindOwnerServlet";
            String queryvars = "&t1=" + t1;
            String pagename = "page";
            paging.setpagination(cPage, pageno, vfile, queryvars, pagename);
            String pagination = paging.getpagination();
Again, all works, but I cannot use @inject, it only works using the "new" keyword.
How can I get the @inject to work?
It's a jakarta 9 web project.
Re: Dependency injection with @inject [message #1842867 is a reply to message #1842866] Sun, 04 July 2021 04:07 Go to previous messageGo to next message
The bean must be either be declared in the CDI standard descriptor beans.xml or be annotated with a CDI annotation (@Named, @RequestScoped, etc.).
In the latter case, the standard descriptor,beans.xml, can be an empty file but it must be present to enable bean discovery.
So you should annotate PageClass with some CDI annotation:
@RequestScoped
and verify that there is an empty beans.xml file in the WEB-INF or the WEB-INF/classes/META-INF directory (since it's a web application, I would put it in the WEB-INF directory).
A prori the @RequestScoped on the Servlet class is not required.
Re: Dependency injection with @inject [message #1842871 is a reply to message #1842867] Sun, 04 July 2021 13:33 Go to previous messageGo to next message
Stephane Thanks for reply. I did all you said, but still not working. No error, but blank pagination. It's as though @inject expects parameters, however I don't pass parameters til later in the servlet like:
paging.setpagination(cPage, pageno, vfile, queryvars, pagename);  // then
So I need an instance of the class, but actual usage comes later in the servlet. As said I am loading class like:
However I would like to use the more modern @inject. I even tried moving at inject just before usage. Does @inject not work for a class that has to pass parameters later? Thanks
Edit:
I did a singleton, it works also:
package net;
public class PGClass {
    private static final PGClass instance
            = new PGClass();
    String pagination;
    private PGClass() {
    public static PGClass getInstance() {
        return instance;
    public String getpagination(int maxPage, int cpage, String vfile, String queryvars, String pageName) {
        etc, same code from first pagination class
And usage:
String pagination = net.PGClass.getInstance().getpagination(cPage, pageno, vfile, queryvars, pagename);
Do you think such a class is okay in this use case? I would still like @inject to work however. But I tried for hours with no luck.
[Updated on: Sun, 04 July 2021 14:56] by Moderator
Re: Dependency injection with @inject [message #1842872 is a reply to message #1842871] Sun, 04 July 2021 15:13 Go to previous messageGo to next message
Can you show us the updated net.PageClass?
Re: Dependency injection with @inject [message #1842873 is a reply to message #1842872] Sun, 04 July 2021 16:22 Go to previous messageGo to next message
Nitin the the update just has the new name PGClass:
package net;
            = new PGClass();
    String pagination;
    private PGClass() {
        return instance;
        int fpage = 1;
        int page = cpage;
        int limit = 3;
        int pageno = cpage;
        int spage = cpage;
        int khigh = 0;
        int klow = 0;
            if (pageno > 1) {
            if (spage == 1) {
                klow = spage;
                khigh = limit;
            if (spage > 1) {
                if (lower < 1) {
                    klow = 1;
                    khigh = limit;
                } else {
                    klow = lower;
                    khigh = upper;
                    khigh = maxPage;
                if (i == pageno) {
                } else {
        } else {
            if (pageno != 1) {
                if (i == pageno) {
                } else {
        //String tmppag;
        if (maxPage < 2) {
            pag = "";
Usage in the servlet:
And passed to jsp view:
request.setAttribute("mypager", pagination);
// other request
RequestDispatcher dispatcher = request.getRequestDispatcher(displaypage);
And in jsp page:
${mypager}
Also I am still tweaking as needed but it works. I just cannot figure out how to use @inject with the pagination.
[Updated on: Sun, 04 July 2021 16:31] by Moderator
Re: Dependency injection with @inject [message #1842874 is a reply to message #1842873] Sun, 04 July 2021 16:39 Go to previous messageGo to next message
Which Jakarta EE 9 server are you using?
Could you show the code of the Servlet?
[Updated on: Sun, 04 July 2021 16:44] by Moderator
Re: Dependency injection with @inject [message #1842878 is a reply to message #1842874] Sun, 04 July 2021 19:59 Go to previous messageGo to next message
apache-tomcat-10.0.7
The servlet is just standard doGet stuff. But right now it is a mess from experimenting, needs to be cleaned up. I will post tomorrow if I get a chance.
Re: Dependency injection with @inject [message #1842879 is a reply to message #1842878] Sun, 04 July 2021 20:13 Go to previous messageGo to next message
You have not annotated the PGClass class with a scope as directed.
[Updated on: Sun, 04 July 2021 20:13] by Moderator
Re: Dependency injection with @inject [message #1842880 is a reply to message #1842879] Sun, 04 July 2021 22:33 Go to previous messageGo to next message
Nitin I did try that: I changed name to PagingClass. And I added a blank bean.xml.
package net;
@RequestScoped
public class PagingClass {
    private static final PagingClass instance
            = new PagingClass();
    String pagination;
    private PagingClass() {
    public static PagingClass getInstance() {
        return instance;
        int fpage = 1;
        int page = cpage;
        int limit = 3;
        int pageno = cpage;
        int spage = cpage;
        int khigh = 0;
        int klow = 0;
            if (pageno > 1) {
            if (spage == 1) {
                klow = spage;
                khigh = limit;
            if (spage > 1) {
                if (lower < 1) {
                    klow = 1;
                    khigh = limit;
                } else {
                    klow = lower;
                    khigh = upper;
                    khigh = maxPage;
                if (i == pageno) {
                } else {
        } else {
            if (pageno != 1) {
                if (i == pageno) {
                } else {
        //String tmppag;
        if (maxPage < 2) {
            pag = "";
And top of servlet:
package net;
import jakarta.servlet.*;
import java.sql.*;
import java.util.ArrayList;
import SQLBean.ConnBean;
import java.io.IOException;
import java.io.PrintWriter;
import java.util.List;
import jakarta.servlet.ServletException;
import jakarta.servlet.annotation.MultipartConfig;
import jakarta.servlet.annotation.WebServlet;
import jakarta.servlet.http.HttpServlet;
import jakarta.servlet.http.HttpServletRequest;
import jakarta.servlet.http.HttpServletResponse;
 * @author jimwin7a
@MultipartConfig
@WebServlet(
    @Inject net.PagingClass mypager;
And tried to use like:
String pagination = mypager.getpagination(cPage, pageno, vfile, queryvars, pagename);
However without @inject, this does work:
    net.PagingClass mypager = net.PagingClass.getInstance();
I tried everything with original getter setter class and the new singleton class, but for now am using the singleton. I just can't seem to get @inject to work.
I even tried @EJB I saw in an S.O. post. I even took out the returning of the instance. So far only thing working is:
[Updated on: Sun, 04 July 2021 23:05] by Moderator
Re: Dependency injection with @inject [message #1842882 is a reply to message #1842878] Mon, 05 July 2021 01:10 Go to previous messageGo to next message
Jim Whitaker wrote on Sun, 04 July 2021 23:59
Tomcat is just a Servlet/JSP container, it doesn't provides all the Jakarta EE Web API.
I think it doesn't have CDI by default, you have to add it.
Re: Dependency injection with @inject [message #1842897 is a reply to message #1842866] Mon, 05 July 2021 11:45 Go to previous messageGo to next message
I've tested with a equivalent simplified equivalent project:
CDI bean:
package test.jee9.cdi;
@RequestScoped
public class TestCdibean {
	private String param;
	public TestCdibean() {
		super();
	public void setParam(String p) {
		this.param = (p == null) ? "empty" : p ;
	public String getParam() {
		return param.toUpperCase();
Servlet :
@WebServlet("/TestServlet")
public class TestServlet extends HttpServlet {
	private static final long serialVersionUID = 1L;
	@Inject
	private TestCdibean bean;
    public TestServlet() {
        super();
	protected void doGet(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
		String param = request.getParameter("p");
		bean.setParam(param);
		param = bean.getParam();
		request.setAttribute("p", param);
		request.getRequestDispatcher("/page.jsp").forward(request, response);
JSP:
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
    pageEncoding="ISO-8859-1"%>
<!DOCTYPE html>
<html>
<head>
<meta charset="ISO-8859-1">
<title>Insert title here</title>
</head>
<body>
<p>${p}</p>
</body>
</html>
beans.xml : empty file in Web-INF
I've tested it on Apache TomEE 9.0.0-M7-webprofile and it is working as expected.
TomEE is Tomcat extended to fulfill JavaEE/Jakarta EE Web Profile specification, so it comes with CDI preinstalled.
Re: Dependency injection with @inject [message #1842906 is a reply to message #1842897] Tue, 06 July 2021 00:25 Go to previous messageGo to next message
Thank you so much, all who helped. That Apache TomEE 9.0.0-M7-webprofile did the trick, also is the super part needed, I added it. But all works now.
I had TomEE up and running in minutes, new project, copied web pages and beans and servlets over, assigned TomEE, added the super, clean and build, worked.
For TomEE in netbeans to work I had to uncheck "Use IDE Proxy Settings" under the Platform tab. However with Tomcat 10 I didn't have to, any ideas why?
But happy all is good, I now know why inject wasn't working.
Stephane I basically just changed my original code as needed to match your example, and added the super.
[Updated on: Tue, 06 July 2021 00:37] by Moderator
Re: Dependency injection with @inject [message #1842912 is a reply to message #1842906] Tue, 06 July 2021 03:10 Go to previous messageGo to next message
For a CDI bean a constructor or a producer is mandatory.
For TomEE in Netbeans, I don't know what the problem is.
However, since TomEE is basically Tomcat++, I would expect the Tomcat 10 plugin to work.
In Eclipse IDE, for example you have to declare TomEE 9 servers as Tomcat 10 instances.
Re: Dependency injection with @inject [message #1842931 is a reply to message #1842912] Tue, 06 July 2021 19:27 Go to previous message
All is working in Netbeans. I tried to also install TomEE in Eclipse, but no CDI is working. TomEE works, but @inject is not. I even followed this:
https://tomee.apache.org/latest/docs/tomee-and-eclipse.html
Any idea why Dependency Injection is working in netbeans but not eclipse. Identical projects.
Moving to new discussion.
[Updated on: Tue, 06 July 2021 19:55] by Moderator
Previous Topic:Cant run Karel the robot or other kinds of programs in Eclipse
Next Topic:[Solved] TomEE in Eclipse IDE 2021-06
Current Time: Sun Nov 02 16:26:30 EST 2025
Powered by FUDForum. Page generated in 0.12048 seconds
