Home » Newcomers » Newcomers » How do I add a multi-column row to a TableViewer?
How do I add a multi-column row to a TableViewer? [message #1842865] Sat, 03 July 2021 18:27 Go to next message
I am trying to get a simple example working to start with, two columns with each row an array of 2 strings. Below is the result of studying a number of examples and the API javadoc. The TableItem consisting of {"display", "<expression>"} exists in the table but does not appear in the view. How is a row added to a TableView?
public void createPartControl(Composite parent) {
viewer = new TableViewer(parent, SWT.FULL_SELECTION);
Table viewerTable = viewer.getTable();
viewerTable.setLayoutData(new GridData(GridData.FILL_BOTH));
TableViewerColumn kindCol = new TableViewerColumn(viewer, SWT.LEFT);
kindCol.setLabelProvider(new CellLabelProvider() {
public void update(ViewerCell cell) {
// This is never called
TableViewerColumn textCol = new TableViewerColumn(viewer, SWT.RIGHT);
textCol.setLabelProvider(new CellLabelProvider() {
// viewerTable.getColumnCount() == 2 at this point
String[] rowTextArray = new String[] {"display", "<expression>"};
TableItem tableRow = new TableItem(viewerTable, SWT.NONE);
tableRow.setData(rowTextArray);
// tableRow.getText() is always a single String, maybe a row label?
// viewerTable.getItems().length == 1
// viewerTable.getItem(0).getData() == rowTextArray
// Various attempts of this kind result in NPEs deep in the framework.
// Why does TableViewer#setInput require a parameter? Others don't.
// viewer.setContentProvider(new IStructuredContentProvider() {
// @Override
// public Object[] getElements(Object inputElement) {
// return rowText;
//// return listRowText;
//// return new TableItem[] {tableRow};
//// return viewerTable.getItems();
// viewer.setInput(rowText);
// viewer.setInput(allRows);
// viewer.setInput(listRowText);
// viewer.setInput(tableRow);
Re: How do I add a multi-column row to a TableViewer? [message #1842868 is a reply to message #1842865] Sun, 04 July 2021 04:33 Go to previous messageGo to next message
Perhaps looking at the JFace Snippets helps. For your case I'd suggest to start with Snippet003.
Basically: set a label provider, and set a content provider. Then set your model as input: viewer.setInput(rowTextArray);. With an array as model, you'd use ArrayContentProvider.getInstance() as content provider.
Re: How do I add a multi-column row to a TableViewer? [message #1842870 is a reply to message #1842868] Sun, 04 July 2021 11:52 Go to previous message
Thanks! That put me on track. I did need to nest rowTextArray,
Object[] tableWithOneRow = new Object[] {rowTextArray};
viewer.setInput(tableWithOneRow);
Next step is to associate cell editors with each column. The Javadoc for ArrayContentProvider says it "handles the case where the viewer input is an unchanging array or collection of elements." I'm assuming that means if the structure-of-arrays stay the same then I can replace an element in rowTextArray and just do a refresh.
Previous Topic:Application Android whit Server GlassFish
Next Topic:Cant run Karel the robot or other kinds of programs in Eclipse
Current Time: Sun Jul 20 22:41:08 EDT 2025
Powered by FUDForum. Page generated in 0.08375 seconds
