| How to validate only part of model [message #1842761] |
Wed, 30 June 2021 12:55  |
Hello
I need to validate only part of model.
Is it possible to pass list of root objects. In this case only parent object and references will be validated?
Arseniy Isakov
| Re: How to validate only part of model [message #1842975 is a reply to message #1842971] |
Thu, 08 July 2021 07:20   |
So your final example has to look like this
package org.eclipse.epsilon.examples.standalone.evl;
import java.io.File;
import java.util.Arrays;
import java.util.Collection;
import java.util.HashMap;
import java.util.List;
import java.util.stream.Collectors;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.emf.ecore.xmi.impl.XMIResourceFactoryImpl;
import org.eclipse.epsilon.common.module.ModuleElement;
import org.eclipse.epsilon.common.parse.AST;
import org.eclipse.epsilon.common.parse.problem.ParseProblem;
import org.eclipse.epsilon.emc.emf.InMemoryEmfModel;
import org.eclipse.epsilon.eol.exceptions.models.EolModelElementTypeNotFoundException;
import org.eclipse.epsilon.eol.exceptions.models.EolModelNotFoundException;
import org.eclipse.epsilon.evl.EvlModule;
import org.eclipse.epsilon.evl.dom.ConstraintContext;
import org.eclipse.epsilon.evl.execute.context.IEvlContext;
* Demonstrates subclassing EvlModule to only check constraints against a
* selection of model elements
public class SelectiveEvlModule extends EvlModule {
protected static List<EObject> rootEObjects;
public ModuleElement adapt(AST cst, ModuleElement parentAst) {
ModuleElement moduleElement = super.adapt(cst, parentAst);
if (moduleElement instanceof ConstraintContext) {
return new SelectiveConstraintContext();
return moduleElement;
public HashMap<String, Class<?>> getImportConfiguration() {
HashMap<String, Class<?>> importConfiguration = super.getImportConfiguration();
importConfiguration.put("evl", SelectiveEvlModule.class);
return importConfiguration;
class SelectiveConstraintContext extends ConstraintContext {
public Collection<?> getAllOfSourceKind(IEvlContext context)
throws EolModelElementTypeNotFoundException, EolModelNotFoundException {
// Only return a subset containing elements which are
// descendants of one of the root objects
return super.getAllOfSourceKind(context).stream().filter(e -> shouldCheck(e)).collect(Collectors.toList());
protected boolean shouldCheck(Object object) {
// Only check elements which are decendants of one of the
// root objects
return EcoreUtil.isAncestor(rootEObjects, (EObject) object);
public void setRootEObjects(List<EObject> rootEObjects) {
this.rootEObjects = rootEObjects;
public List<EObject> getRootEObjects() {
return rootEObjects;
public static void main(String[] args) throws Exception {
SelectiveEvlModule module = new SelectiveEvlModule();
ResourceSetImpl resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMIResourceFactoryImpl());
Resource resource = resourceSet.createResource(URI.createURI("foo.ecore"));
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
// Create 2 classes C1 and C2 with one attribute each
EClass c1 = EcoreFactory.eINSTANCE.createEClass();
c1.setName("C1");
EAttribute a1 = EcoreFactory.eINSTANCE.createEAttribute();
a1.setName("a1");
c1.getEStructuralFeatures().add(a1);
EClass c2 = EcoreFactory.eINSTANCE.createEClass();
c2.setName("C2");
EAttribute a2 = EcoreFactory.eINSTANCE.createEAttribute();
a2.setName("a2");
c2.getEStructuralFeatures().add(a2);
resource.getContents().add(c1);
resource.getContents().add(c2);
InMemoryEmfModel model = new InMemoryEmfModel(resource);
// Constraint for EAttibute
module.parse(new File("mainRules.evl"));
if (module.getParseProblems().size() > 0) {
for (ParseProblem problem : module.getParseProblems()) {
System.out.println(problem.toString());
return;
module.getContext().getModelRepository().addModel(model);
// Only elements under C1 (i.e. attribute a1) should be checked
module.setRootEObjects(Arrays.asList(c1));
module.execute();
FUDForum. Page generated in 0.05835 seconds
