Home » Language IDEs » ServerTools (WTP) » eclipse 3.3 and WTP
eclipse 3.3 and WTP [message #182421] |
Thu, 09 November 2006 18:06  |
Originally posted by: kevin.hanrahan.clickcommerce.com
I would like to use the enhanced refactoring history capabilities from
eclipse 3.3. I would like to use this on a WTP eclipse project.
How should I install WTP on eclipse 3.3?
The manual approach of copying features/plugins does not work, nor does
it work through the update manager.
Re: eclipse 3.3 and WTP [message #184269 is a reply to message #184262] |
Fri, 08 December 2006 23:45   |
Konstantin Komissarchik wrote:
> The build that you referenced works with Eclipse 3.3M3. You can find the
> link to the correct eclipse platform download on the build page. Look
> for the "Requirements" section.
It "Requirements" section says it requires eclipse 3.3. I am trying to
install it with configuration pasted below.
Requirements installed are
# The EMF driver used in this build is emf-sdo-xsd-SDK-2.3.0M3.zip
# The GEF driver used in this build is GEF-SDK-3.2.1.zip
# Java EMF Model Runtime driver used in this build is JEM-SDK-1.2.1.zip
# Data Tools Platform (DTP) driver used in this build is dtp-sdk_1.0M3.zip
When I installed WTP it was disabled and when I tried to enable it I got
following errors:
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
WST Common Core (1.6.0.v200611161425--AXrVWXdxnEfAsK) requires
feature "org.eclipse.emf (2.2.0)", or equivalent.
WST Server Core (1.6.0.v200611161425------1G955G7777) requires
feature "org.eclipse.rcp (3.2.0)", or equivalent.
WST XML Core (1.6.0.v200609120056--3YIAAYEEEZDNAA) requires feature
WST Web Services Core (1.6.0.v200611161425--4hNDDhGWJcJTQc) requires
feature "org.eclipse.platform (3.2.0)", or equivalent.
WST Web Core (1.6.0.v200611161425--4hNDDhHNJeHgIR) requires feature
*** System properties:
eclipse.buildId=I20061102-1715
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-launcher
/mnt/data/work/eclipse3.3/eclipse/./eclipse
-name
Eclipse
-showsplash
600
-exitdata
8800b
-vm
/mnt/data/work/eclipse3.3/eclipse/./jre/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1165638847146
eclipse.vm=/mnt/data/work/eclipse3.3/eclipse/./jre/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/mnt/data/work/eclipse3.3/eclipse/./startup.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/mnt/data/work/eclipse3.3/eclipse/./startup. jar
java.class.version=49.0
java.endorsed.dirs=/mnt/data/work/jdk1.5.0_06/jre/lib/endors ed
java.ext.dirs=/mnt/data/work/jdk1.5.0_06/jre/lib/ext
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.19
org.osgi.framework.processor=amd64
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax
..sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.row set.serial,javax.sql.rowset.spi,javax.swing,javax.swing.bord er,javax.swing.colorchooser,javax.swing.event,javax.swing.fi lechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swin g.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,j avax.swing.table,javax.swing.text,javax.swing.text.html,java x.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tr ee,javax.swing.undo,javax.transaction,javax.transaction.xa,j avax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.pa rsers,javax.xml.transform,javax.xml.transform.dom,javax.xml. transform.sax,javax.xml.transform.stream,javax.xml.validatio n,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA_ 2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,o rg.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA .TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingC ontextExtPackage,org.omg.CosNaming.NamingContextPackage,org. omg.Dynamic,org.omg.DynamicAny,
org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
os.arch=amd64
os.name=Linux
os.version=2.6.19
osgi.arch=x86_64
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/mnt/data/work/eclipse3.3/eclipse/configura tion/org.eclipse.osgi/bundles
osgi.configuration.area=file:/mnt/data/work/eclipse3.3/eclip se/configuration/
osgi.framework=file:/mnt/data/work/eclipse3.3/eclipse/plugin s/org.eclipse.osgi_3.3.0.v20061101.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.0.v20061101
osgi.os=linux
osgi.splashLocation=/mnt/data/work/eclipse3.3/eclipse/plugin s/org.eclipse.platform_3.2.0.v20060829/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/mnt/data/work/eclipse3.3/eclipse/plugins
sun.arch.data.model=64
sun.io.unicode.encoding=UnicodeLittle
sun.management.compiler=HotSpot 64-Bit Server Compiler
Re: eclipse 3.3 and WTP [message #185403 is a reply to message #184982] |
Sat, 23 December 2006 03:37  |
I experience the same problem wit WTP 2.0.
Clean (only that bundles which are required by WTP) installation of WTP
looks OK, no problem is reported, but there is almost no functionality of
the bundle (no labels in Preferences, no editors etc.).
Tried disable-enable, it does not work, no warnings, no errors... and no
functions :(
Any suggestions?
Thanks.
Current Time: Wed Jul 23 08:49:10 EDT 2025
Powered by FUDForum. Page generated in 0.67867 seconds
