Plugin Product Takes 10 minutes to start [message #1842615] |
Fri, 25 June 2021 10:45  |
We have created a product based on multiple plugins. We recently upgraded the Eclipse version it runs on from 4.6.3 to 4.19.
When running this product, sometimes (seems to relate to starting that particular build of the product first-time) it can take several minutes (10 or more) before the workspace prompt is even shown.
I've been unable to pipe the osgi console output to a file because it opens its own window for the console (if anyone knows how to do that please let me know) but I have captured some of the output and it seems to be looping round in the configuration area:
The OSGI console seems to loop:
Restoring artifact repository file:/C:/<hidden_path>/configuration/org.eclipse.osgi/1329/data/631451066
Validating and loading metadata repository file:/<hidden_path>/configuration/org.eclipse.osgi/1329/data/631451066/
Then goes off and does this (whatever that is) for all plugins in the product (inc/ framework plugins) (several thousand lines written to the console here)
parseHeader: com.fasterxml.jackson.annotation;version=2.11.1
parseHeader: com.fasterxml.jackson.core.jackson-annotations
before going back to Restoring another, different, repository file. Rinse and repeat.
It does eventually show the workspace prompt, though I couldn't capture the exact point that it broke itself free, presumably it ran out of artifact repositories to restore and then got around to showing the workspace prompt.
Does anyone have any clue as to what might be going on here??? (It's not going to be an option for our customers just to delete that configuration area before upgrading their version).
Thanks in advance
Re: Plugin Product Takes 10 minutes to start [message #1843235 is a reply to message #1842665] |
Wed, 21 July 2021 02:57  |
Thanks for your comments, gents. I wasn't able to get to the bottom of this, though I did manage to get OSGi to output debug to a log file, eventually. It was reading through content.xml files, reading headers of stuff in it and then moving on to another content file, and there were hundreds of these p2-style folders and it just took ages. What was most odd is that it only did it on certain machines, mine not being one of them even with a clone of the offending configuration area.
In the end I've just had to effectively wipeout the configuration folder. Not the best outcome but it'll work.
FUDForum. Page generated in 0.05629 seconds
