Home » Modeling » EMF » Client context org.eclipse.egf.pattern.ui.patternContext failed with a run-time exception.(EMF validation failed with !MESSAGE Client context org.eclipse.egf.pattern.ui.patternContext failed with a run-time exception. It is disabled; its constraint bindings are removed from the system.)
Client context org.eclipse.egf.pattern.ui.patternContext failed with a run-time exception. [message #1842605] Fri, 25 June 2021 04:59 Go to next message
We are using the Eclipse EMF validation plugin for our custom validation. It is working fine in windows but in Linux, we are facing the below issue.
!ENTRY org.eclipse.emf.validation 4 114 2021-06-17 21:21:16.267
!STACK 0
java.lang.IllegalStateException: Client context org.eclipse.egf.pattern.ui does not exist in constraint binding defined by plug-in <missing argument>.
	at org.eclipse.emf.validation.internal.service.ClientContext$1.selects(ClientContext.java:99)
	at org.eclipse.emf.validation.internal.service.ClientContextManager.getClientContextsFor(ClientContextManager.java:183)
	at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:204)
	at org.eclipse.emf.validation.internal.service.BatchValidator.doValidate(BatchValidator.java:149)
	at org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:147)
	at org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:126)
	at org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:117)
Any help would be appreciated. Thanks in advance.
Re: Client context org.eclipse.egf.pattern.ui.patternContext failed with a run-time exception. [message #1842630 is a reply to message #1842605] Fri, 25 June 2021 14:32 Go to previous messageGo to next message
EMFv is close to obsolete with just about no support I suggest you investigate the improved facilities of EMF's EValidator or OCLinEcore.
Ed Willink
Re: Client context org.eclipse.egf.pattern.ui.patternContext failed with a run-time exception. [message #1842666 is a reply to message #1842630] Mon, 28 June 2021 03:03 Go to previous message
Hi Ed,
I have one more doubt. Actually, it is working in windows but failing in Linux. If I provide the below arguments in command line
 -os win32 -ws win32
then it is working in Linux.
Can we change BootLoader constants for the eclipse RCP application?
Pankaj
Previous Topic:eContainer nulls attribute despite containment
Next Topic:Parsing a nested JSON containment references list
Current Time: Mon Jul 21 08:26:32 EDT 2025
Powered by FUDForum. Page generated in 0.03390 seconds
