DATA_TYPE_ERROR in remote OPC UA server example [message #1841993] |
Sun, 06 June 2021 11:06  |
I was following the tutorial "Read and write OPC UA variables on a remote server". The PUBLISH_1 and SUBSCRIBE_1 are working well with the opc ua server.
But, there is an error with the CLIENT_X_X and the error is DATA_TYPE_ERROR. The CLIENT_0_1 and CLIENT_1_0 are obtained by modifying the interfaces and names of CLIENT_1. I also checked the data type of SD_1 and it is ANY. The details of the application, devices, and resource configuration can be found via the attached images.
Specifics of the testing environment:
- two forte (with Open62541, version 1.0) instances running in the same cloud VM
- two port numbers, 61499 and 61500, are exposed from the cloud VM
- 4diac IDE version is 1.12.2
Thanks to anyone who can help me solve this issue.
FUDForum. Page generated in 0.06585 seconds
