Home » Modeling » EMF » Parsing a nested JSON containment references list
Parsing a nested JSON containment references list [message #1842423] Fri, 18 June 2021 04:56 Go to next message
I am trying to define an model using Xcore for the following simplified JSON data:
(The category object contains many more attributes I have omitted here.)
  "foo": "bar",
  "categories": [
        "categoryName": "root"
        "categoryName": "a"
        "categoryName": "b"
I have come up with the following model so far:
class Root {
  String foo
  contains CategoryPath[] categories
interface CategoryPath wraps org.eclipse.emf.common.util.EList<Category>
class Category {
  String categoryName
This model generates the following Java Getter in my Root class, which is fine:
EList<EList<Category>> getCategories();
Now I am using the emfjson library, which moved to EMF.cloud recently, to parse the above JSON instance into EObjects. Sadly, this parsing fails because of the nested list.
Is this a limitation of the emfjson library or should I maybe model this differently?
Kind regards
Jan
[Updated on: Thu, 24 June 2021 05:14] by Moderator
Re: Parsing a nested JSON containment references list [message #1842442 is a reply to message #1842423] Sat, 19 June 2021 07:47 Go to previous messageGo to next message
Hi Jan,
could you post this in the channel of EMF.cloud please? https://www.eclipse.org/emfcloud/support/
Also could you add the error message you get? The model seems pretty standard, should actually work with the converter. Ideally you post a small reproducer, too.
best regards,
Jonas
Re: Parsing a nested JSON containment references list [message #1842579 is a reply to message #1842442] Thu, 24 June 2021 05:07 Go to previous messageGo to next message
Hi Jonas,
even without the JSON part I still get an error.
This is my model:
class Root {
  String foo
class Category {
  String categoryName
interface CategoryPath wraps org.eclipse.emf.common.util.EList<Category> {}
I generated the Java classes and tried to do the following:
var root = SampleFactory.eINSTANCE.createRoot();
var category = SampleFactory.eINSTANCE.createCategory();
var categoryPath = new BasicEList<Category>();
categoryPath.add(category);
root.getCategories().add(categoryPath);
When executing this, the following error is thrown:
class org.eclipse.emf.common.util.BasicEList cannot be cast to class org.eclipse.emf.ecore.InternalEObject (org.eclipse.emf.common.util.BasicEList and org.eclipse.emf.ecore.InternalEObject are in unnamed module of loader 'app')
java.lang.ClassCastException: class org.eclipse.emf.common.util.BasicEList cannot be cast to class org.eclipse.emf.ecore.InternalEObject (org.eclipse.emf.common.util.BasicEList and org.eclipse.emf.ecore.InternalEObject are in unnamed module of loader 'app')
	at org.eclipse.emf.ecore.util.EcoreEList.inverseAdd(EcoreEList.java:261)
	at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:312)
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:304)
Re: Parsing a nested JSON containment references list [message #1842584 is a reply to message #1842579] Thu, 24 June 2021 07:39 Go to previous messageGo to next message
Yes, the model looks nonsensical. The interface CategoryPath wrapping a list and then used in a containment reference would only work if you have some EObject that also implements EList<Category>, but I don't think it's sensible to create such a thing.
Re: Parsing a nested JSON containment references list [message #1842668 is a reply to message #1842584] Mon, 28 June 2021 04:34 Go to previous messageGo to next message
I agree, it feels like I'm doing something, that is not supposed to be done here.
Does this mean the above JSON payload cannot be mapped to an Ecore model?
Re: Parsing a nested JSON containment references list [message #1842669 is a reply to message #1842668] Mon, 28 June 2021 05:17 Go to previous messageGo to next message
If you really want to instantiate a CategoryPath in your model then it needs to be a Class not an Interface.
Probably much simpler to leave it out so that "contains Category[] categories" maintains one aggregate for free rather than an aggregate of aggregates
Ed Willink
Re: Parsing a nested JSON containment references list [message #1842671 is a reply to message #1842669] Mon, 28 June 2021 07:19 Go to previous messageGo to next message
Thanks, I understand.
Flattening the list sadly discards some information, which is not obvious from my example: In this particular case above, the object belongs to the category path a/b. It could also belong to a/d/e and f/g/h for example. Having a flattened list of a, b, a, d, e, f, g, h would be problematic because I cannot restore the categories' hierarchy any more.
I will probably create a CategoryPath class holding a list of categories. This means, I need to preprocess the above JSON first, before being able to parse it then.
Re: Parsing a nested JSON containment references list [message #1842672 is a reply to message #1842671] Mon, 28 June 2021 07:48 Go to previous message
Perhaps your model should be a little more like the com.google.gson.JsonElement hierarchy where there is a JsonArray class that represents a "list". I.e., if you want a list of lists, the outer list needs to be some type of EClass such that the instance is some type of EObject.
Previous Topic:Client context org.eclipse.egf.pattern.ui.patternContext failed with a run-time exception.
Next Topic:[EMF] parse enum values surrounded by whitespace
Current Time: Mon Jul 21 00:04:33 EDT 2025
Powered by FUDForum. Page generated in 0.04918 seconds
