Re: How to register a listener to datachange on Form or Page [message #1842363 is a reply to message #1842347] |
Thu, 17 June 2021 03:35   |
to check, whether a table is dirty, you can use the method isSaveNeeded of ITableField.
If you want to listen for changes, you can add a table listener to the table using ITable.addTableListener. You are probably interested in TableEvent.TYPE_ROWS_INSERTED, TableEvent.TYPE_ROWS_UPDATED, TableEvent.TYPE_ROWS_DELETED.
If you need to be notified when a form is closed, add a form listener to the form using IForm.addFormListener with the type FormEvent.TYPE_CLOSED. With the IForm.getCloseSystemType() you can determine whether the user pressed Ok or Cancel, or just use IForm.isFormStored().
If you want, you can then trigger a DataChangeEvent, as described in the linked post, to inform other widgets that your data changed, but I don't think this is necessary for your use case.
If you want to get informed when another user changes the data displayed on your form, then you should use client notifications.
FUDForum. Page generated in 0.03525 seconds
