Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » question about opc_ua -- how can i get client_0_1 and client_1_0 FBs(opc_ua)
question about opc_ua -- how can i get client_0_1 and client_1_0 FBs [message #1842135] Wed, 09 June 2021 22:28 Go to next message
follow the example, I tested how to use subscribe and publish for opc ua server.
But when i want to test opc ua client, I can't found client_0_1 and client_1_0 FBs.
should I just create new FBs, and recomplie the forte runtime?
which type FB need create? how to write the inner code? thx
Re: question about opc_ua -- how can i get client_0_1 and client_1_0 FBs [message #1842140 is a reply to message #1842135] Thu, 10 June 2021 02:49 Go to previous messageGo to next message
Yes you can just easily create the FBs, by copy pasting an existing client block and adjust the name and interface to your needs. As long as you follow the convention of naming the type CLIENT_X_Y, where I X is the number of SDs and Y is the number of RDs you don't need to change anything in 4diac FORTE. During deployment 4diac FORTE parses the type name and creates the right instance.
Re: question about opc_ua -- how can i get client_0_1 and client_1_0 FBs [message #1842179 is a reply to message #1842140] Thu, 10 June 2021 22:22 Go to previous messageGo to next message
thx a lot. problem had been solved!
Re: question about opc_ua -- how can i get client_0_1 and client_1_0 FBs [message #1842195 is a reply to message #1842179] Fri, 11 June 2021 06:24 Go to previous message
Great!
Previous Topic:mqtt question, help pls
Next Topic:Sample projects
Current Time: Wed Jul 30 07:36:43 EDT 2025
Powered by FUDForum. Page generated in 0.04277 seconds
