Home » Eclipse Projects » Eclipse Titan » Error when installing TITAN on windows10
Error when installing TITAN on windows10 [message #1840596] Tue, 20 April 2021 06:49 Go to next message
I have faced an error when trying to install Titan on windows 10
I have followed steps described in this tutorial :
https://www.eclipse.org/forums/index.php/t/1103718/
When I tape make -j I obtained the attached exception
Note that I have installed all required cygwin packages
  • Attachment: exception.png
    (Size: 27.45KB, Downloaded 109 times)
Re: Error when installing TITAN on windows10 [message #1840601 is a reply to message #1840596] Tue, 20 April 2021 09:01 Go to previous messageGo to next message
Set the
OLD_LIBEDIT := yes
in the Makfile.cfg
Re: Error when installing TITAN on windows10 [message #1840702 is a reply to message #1840601] Thu, 22 April 2021 04:47 Go to previous messageGo to next message
Thanks a lot.
It was installed now successfully.
[Updated on: Thu, 22 April 2021 04:48] by Moderator
Re: Error when installing TITAN on windows10 [message #1841906 is a reply to message #1840702] Wed, 02 June 2021 13:09 Go to previous message
Hi Mariam,
I would suggest writing that line into Makefile.personal
It will be imported by Makefile.cfg but this way you will not modify Makefile.cfg itself which is a version-controlled file.
BR
Jenő Balaskó
Previous Topic:Eclipse Titan repositories will migrate to GitLab
Next Topic:TTCN-3 typing for RFC 7946 (GeoJSON)
Current Time: Tue Jul 22 09:30:37 EDT 2025
Powered by FUDForum. Page generated in 0.09916 seconds
