Home » Modeling » Papyrus » Obtaining the order of operations of a sequence diagram via Java API (UML2-Papyrus)(Navigate Papyrus model and get detailed information via API)
Obtaining the order of operations of a sequence diagram via Java API (UML2-Papyrus) [message #1841847] Tue, 01 June 2021 04:01 Go to next message
I'm developing a software that takes as input a Papyrus model and through the Java UML2 API I navigate the model.
Specifically, I'm working on a sequence diagram and I would like to know if there is a way to get through the API the order of the executed operations as I see them in the sequence diagram.
Unfortunately, the API outputs the order of the operations as they were entered and not as they are represented in the diagram.
In addition, I tried to migrate to a communication diagram as I was looking for a way to have indices at the beginning of the message (e.g. 1.doX , 2.doY, 3.doZ) but I notice that if I delete message two (2.doY), message 3 does not change index automatically, which makes renaming difficult if there are many messages in one diagram.
Thanks in advance to anyone who can help me!
Re: Obtaining the order of operations of a sequence diagram via Java API (UML2-Papyrus) [message #1842221 is a reply to message #1841847] Sat, 12 June 2021 06:51 Go to previous message
I would use OCL for that.
You could use the OCL console to test the queries.
Maybe its not the best performance solution bit makes it easier, imho.
Previous Topic:UML Profil
Next Topic:Open diagram from a launcher
Current Time: Mon Jul 21 10:47:28 EDT 2025
Powered by FUDForum. Page generated in 0.09254 seconds
