Lexer mixes some inputs even though it is set to non-greedy? [message #1841801] |
Sun, 30 May 2021 13:40  |
I have created a simple grammar, where a value can be a refType:
RefType: 'Aggregate' | 'Composite' | 'Association';
When the value is set to Aggregate or Association, it does not give an error. However, when Composite is written, it gives "no viable alternative at character 'o'. In the DSL it happens at "value": "Composite" . It is the second to last parser rule named ClassReferences in the grammar, at this exact line: '"value"' ':' '"' typeValue = RefType '"'.
I have had a similar error before which was fixed by setting lexer to being greedy:
parserGenerator = {
options = {
backtrackLexer = true
This however doesn't solve it this time, and I don't really get how changing Composite to Aggregate or Association fixes the problem.
The grammar:
Model:
{Model}
'[' tables += Table? (',' tables += Table)* ']'
Table:
ClassTable | ClassReferencesTable
ClassTable:
{ClassTable}
'"Name"' ':' '"Class"' ','
'"Table"' ':' '['
class += Class? (',' class += Class)*
Class:
'"Name"' ':' '{'
'"column"' ':' nameColumn = INT ','
'"row"' ':' nameRow = INT ','
'"value"' ':' name = STRING
'"References"' ':' '['
((references += ClassReferences (',' references += ClassReferences)*) | (references += ClassReferencesReference (',' references += ClassReferencesReference)*))
ClassReferencesTable:
{ClassReferencesTable}
'"Name"' ':' '"ClassReferences"' ','
'"Table"' ':' '['
references += ClassReferences? (',' references += ClassReferences)*
ClassReferencesReference:
'"Name"' ':' '{'
'"column"' ':' column = INT ','
'"row"' ':' row = INT ','
'"value"' ':' name = [ClassReferences|STRING]
ClassReferences:
'"Type"' ':' '{'
'"column"' ':' typeColumn = INT ','
'"row"' ':' typeRow = INT ','
'"To"' ':' '{'
'"column"' ':' toColumn = INT ','
'"row"' ':' toRow = INT ','
'"value"' ':' toValue = [Class|STRING]
terminal NULL: 'null';
terminal ID: '^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
terminal STRING: '"OKZVVTSPKHOVYSMU' -> 'SQPSUQMWUPQSBXDT"';
terminal INT returns ecore::EInt: ('0'..'9')+;
terminal FLOAT: '-'? INT? '.' INT (('E'|'e') '-'? INT)?;
terminal BOOLEAN: 'true' | 'false';
terminal ML_COMMENT: '/*' -> '*/';
terminal SL_COMMENT: '//' !('\n'|'\r')* ('\r'? '\n')?;
terminal WS: (' '|'\t'|'\r'|'\n')+;
terminal ANY_OTHER: .;
The DSL:
"Name": "Class",
"Table": [
"Name": {
"column": 0,
"row": 4,
"value": "OKZVVTSPKHOVYSMUSchoolSQPSUQMWUPQSBXDT"
"References": [
"Type": {
"column": 1,
"row": 4,
"To": {
"column": 2,
"row": 4,
"value": "OKZVVTSPKHOVYSMUClassRoomSQPSUQMWUPQSBXDT"
"Name": {
"column": 0,
"row": 5,
"References": [
"Type": {
"column": 1,
"row": 5,
"value": "Aggregate"
"To": {
"column": 2,
"row": 5,
[Updated on: Sun, 30 May 2021 15:42] by Moderator
Re: Lexer mixes some inputs even though it is set to greedy? [message #1841826 is a reply to message #1841823] |
Mon, 31 May 2021 07:50  |
Quote:The STRING inputs are retrieved from the user and wrapped "OKZVVTSPKHOVYSMU and SQPSUQMWUPQSBXDT"
Ok. Though you might prefer to name the terminal WRAPPED_STRING to avoid confusing the casual reader and to allow a ValueConverter to unwrap in diagnostics.
Temporaily replacing the " in just STRING by perhaps # might help distinguish a backtracking issue
Ed Willink
FUDForum. Page generated in 0.07307 seconds
