Home » Language IDEs » C / C++ IDE (CDT) » How to index all header files in Eclipse CDT on linux?
How to index all header files in Eclipse CDT on linux? [message #1841634] Mon, 24 May 2021 04:02 Go to next message
I have a C++ project structure like that:
-A
--includes
--- A.h
--source
--- A.cpp
-B
--includes
--- B.h
--source
--- B.cpp
I include "B.h" in A.cpp like " #include <B/B.h> " but it cannot resolve B.h header file. How can i index that header file. I added paths of B.h file but again cannot resolved. Is there an any way to index that header file? or Do i have to include like that " #include <B/includes/B.h> "?
Re: How to index all header files in Eclipse CDT on linux? [message #1841658 is a reply to message #1841634] Tue, 25 May 2021 01:26 Go to previous messageGo to next message
Assuming the "-" indicates a directory level
there is no file named B/B.h
even the compiler won't find it.
But there is one named B/includes/B.h.
The compiler will find it if the project directory is in the include paths.
Note there is a difference between #include <...> and #include "..."
https://stackoverflow.com/a/4932754
http://gcc.gnu.org/onlinedocs/cpp/Include-Syntax.html
the latter is specific to GCC.
The Indexer looks for includes pretty much like the compiler
but it searches paths listed in
Project --> Properties --> C/C++ General --> Preprocessor Include Paths, Macros, etc.
A more detailed description:
https://www.eclipse.org/community/eclipse_newsletter/2013/october/article4.php
Note: you have to tell both the compiler and the Indexer what the paths are.
[Updated on: Tue, 25 May 2021 03:18] by Moderator
Re: How to index all header files in Eclipse CDT on linux? [message #1841749 is a reply to message #1841658] Thu, 27 May 2021 08:46 Go to previous messageGo to next message
Actually, I dont understand that header file in A/includes/A.h can be find from A/source/A.cpp file when I include it like " #include <A/A.h> ". I don't need to add "includes/ " to the path. However, it cannot find B.h header file when I include it like " #include <B/B.h>
Also, i added header files and paths of header files (paths: B/includes/ and B) to Project --> Properties --> C/C++ General --> Paths and Symbols section. Again, it cannot find that header file in B/includes/B.h from A/source/A.cpp when I include it like " #include <B/B.h> ".
I am using MinGW Gcc toolchain.
Re: How to index all header files in Eclipse CDT on linux? [message #1841762 is a reply to message #1841749] Thu, 27 May 2021 22:10 Go to previous messageGo to next message
Actually, I don't understand that header file in A/includes/A.h can be find from A/source/A.cpp file when I include it like " #include <A/A.h> ". I don't need to add "includes/ " to the path.
I don't understand it either. A/A.h doesn't exist if what you've told us is correct.
What you should add to Paths and Symbols is A/includes and B/includes
as absolute paths
and use #include <A.h> and #include <B.h>
OR,
put your project directory in Paths and Symbols and use
#include <A/includes/A.h>
OR,
put A and B (recommend absolute paths) in Paths and Symbols and use
#include <includes/A.h>
#include <includes/B.h>
The key is that whatever is in the include (e.g., #include <X>)
has to be a legitimate file when prepending one of the include directories
That is, <some path on include path list>/X
You can have relative paths on the list
but be aware they are relative to the current directory.
The indexer and compiler are unlikely to be using the same current directory.
You also need to turn on the Managed Build settings provider after adding them.
Paths and Symbols is a shortcut to inform both the compiler and the Indexer
but the Indexer only uses the directories found in
You need the Managed Build settings provider to get them on the list.
[Updated on: Sun, 30 May 2021 04:07] by Moderator
Re: How to index all header files in Eclipse CDT on linux? [message #1841828 is a reply to message #1841762] Mon, 31 May 2021 09:10 Go to previous message
Thanks a lot for your solutions.
Previous Topic:Preserve whitespace between code and comment doesn't?
Next Topic:Error in final launch sequence: Failed to execute MI command: -exec-run
Current Time: Sun Jul 27 04:42:02 EDT 2025
Powered by FUDForum. Page generated in 0.03489 seconds
