Home » Eclipse Projects » RCP Testing Tool » get-cell doesn't work correclty in Virtual tables(get-cell command iterates several times in virtual tables)
get-cell doesn't work correclty in Virtual tables [message #1718543] Sat, 26 December 2015 12:17 Go to next message
It seems that the get-cell command doesn`t work very well in Virtual tables with lazy load. It is easy to check it if this kind of table contains thousands of rows. If I try to get a given cell then I can see how it iterates all rows several times (maybe it depends of the table size). It happens only in virtual tables.
I tried an alternative way to do the same thing. It seems work but it takes few seconds to finish.
1-The problematic way to get cells in virtual tables:
with [get-editor "MyEditor"| get-section Table | get-table] {
   	get-cell 0 1 | click
2-An alternative that works but doesn't return the result immediately.
with [get-editor "MyEditor" | get-section Table | get-table] {
	get-item $columnValue -column $columnName -index $index
  • RCPTT version: 2.0.1
  • AUT under Eclipse Mars 4.5.1
I would like to know if someone have an idea about this problem before submitting it as a bug.
Thank you.
[Updated on: Mon, 04 January 2016 01:37] by Moderator
Re: get-cell doesn't work correclty in Virtual tables [message #1841560 is a reply to message #1718543] Thu, 20 May 2021 11:44 Go to previous message
Can I get a look at your table?
I am understanding what is the name of your column.
Previous Topic:AUT connection is failing , Unable to launch AUT
Next Topic:Can't create Run Configuration for testing RAP application
Current Time: Mon Jul 21 11:30:10 EDT 2025
Powered by FUDForum. Page generated in 0.26463 seconds
