Home » Archived » BIRT » Can you have a parameter (filter) on a computed column(Computed column parameter)
Can you have a parameter (filter) on a computed column [message #1841378] Thu, 13 May 2021 12:01 Go to next message
Is it possible to add a parameter to filter by a computed column and if so how?
I have column which gives the level of a bill of material in Birt as a computed column and would like to have the option to filter by level
[Updated on: Thu, 13 May 2021 12:08] by Moderator
Re: Can you have a parameter (filter) on a computed column [message #1841389 is a reply to message #1841378] Thu, 13 May 2021 22:04 Go to previous messageGo to next message
Yes. Google 'cascading parameter group birt' .
Re: Can you have a parameter (filter) on a computed column [message #1842582 is a reply to message #1841389] Thu, 24 June 2021 06:51 Go to previous message
Hi, thank you, this does work when previewing in Birt, really appreciated, however, when this is in the ERP software it crashes.
Previous Topic:image in text field - or how high is 1.3 cm?
Next Topic:Cannot open the connection for the driver: org.eclipse.birt.report.data.oda.jdbc.
Current Time: Mon Jul 21 03:43:53 EDT 2025
Powered by FUDForum. Page generated in 0.32679 seconds
