Home » Eclipse Projects » Eclipse Scout » How REST call token can be injected in the RunContext as Principal(How REST call token can be injected in the RunContext as Principal)
How REST call token can be injected in the RunContext as Principal [message #1841320] Wed, 12 May 2021 03:21 Go to next message
Hi all,
We need to provide some REST api for our Scout application. We are using a token based authentication. Token is got by first authenticating the user (login, password) and then generated a token to be used in the next calls. So getting detail of a user API method is as follow:
@GET
@Path("get/{id}")
@Produces(MediaType.APPLICATION_JSON)
public UserEntityDo getUserDetail(@HeaderParam("token") String token, @PathParam("id") String id) {
  // Check token validity and return corresponding user name if any
  String username = checkToken(token);
  if (username == null) {
    Response.status(Response.Status.FORBIDDEN).build();
  Subject subject = new Subject();
  subject.getPrincipals().add(new SimplePrincipal(username));
  subject.setReadOnly();
  RunContext runContext = RunContexts.empty().withSubject(subject);
  Map<String, Object> data = runContext.call(new Callable<Map<String, Object>>() {
    public Map<String, Object> call() throws Exception {
      return BEANS.get(IUserService.class).getData(UUID.fromString(id));
  // Build user entity data
  UserEntityDo user = BEANS.get(UserEntityDo.class).withLogin((String) data.get("login"))
      .withLastLoginDate((Date) data.get("lastLoginDate").withFirstName((String) data.get("firstName").withLastName((String) data.get("lastName"));
  return user;
The code work perfectly but we have to use the portion of code from //Check... till //Build... in all our method.
I'am thinking about putting this code within a ServletFilter that will inject the user principal in the RunContext based on the header token, but have no idea how to implement it.
Does anyone have an idea ?
Thanks in advance.
[Updated on: Wed, 12 May 2021 03:46] by Moderator
Re: How REST call token can be injected in the RunContext as Principal [message #1841325 is a reply to message #1841320] Wed, 12 May 2021 05:49 Go to previous messageGo to next message
Seydou Zakou wrote on Wed, 12 May 2021 07:21
Yes, I think that's the correct approach. The only downside is that in a ServletFilter you don't get the nice @HeaderParam convenience from JAX-RS. Instead you have to extract it yourself from the HTTP request. Something like this (untested):
import java.io.IOException;
import javax.security.auth.Subject;
import javax.servlet.Filter;
import javax.servlet.FilterChain;
import javax.servlet.FilterConfig;
import javax.servlet.ServletException;
import javax.servlet.ServletRequest;
import javax.servlet.ServletResponse;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.eclipse.scout.rt.platform.context.RunContexts;
import org.eclipse.scout.rt.platform.security.SimplePrincipal;
public class TokenFilter implements Filter {
  public void init(FilterConfig filterConfig) throws ServletException {
  public void doFilter(ServletRequest request, ServletResponse response, FilterChain chain) throws IOException, ServletException {
    HttpServletRequest req = (HttpServletRequest) request;
    HttpServletResponse resp = (HttpServletResponse) response;
    String token = getToken(req);
      resp.sendError(HttpServletResponse.SC_FORBIDDEN);
    } else {
      Subject subject = createSubject(username);
      RunContexts.copyCurrent(true)
          .run(() -> chain.doFilter(request, response));
  protected String getToken(HttpServletRequest req) {
    // Extract token from HTTP request
    return req.getHeader("token");
  protected String checkToken(String token) {
    // Convert token to username
    return ...;
  protected Subject createSubject(String username) {
    // Create subject from username
    return subject;
  public void destroy() {
Beat
Re: How REST call token can be injected in the RunContext as Principal [message #1841386 is a reply to message #1841325] Thu, 13 May 2021 19:51 Go to previous message
Hello Beat,
Thank you for your response. I implemented you suggestion and it works.
Note that I had to exclude /api/* from UiServlet's AuthFilter in web.xml to get rid of 403 error response.
Previous Topic:Is it posssible to set the outline to top
Next Topic:Selecting buttons in a RadioButtonGroup
Current Time: Tue Sep 16 19:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.04138 seconds
