Home » Eclipse Projects » Sirius » Container drop and container creation(Container drop)
Container drop and container creation [message #1790908] Wed, 20 June 2018 01:58 Go to next message
1)Im new to sirius I went through the concepts of sirius I was not able to understand about Container drop. Can someone Please explain me about container drop using some example
2)I have to create the following
Elemets->computationMethod->feature(compuInternalToPhys)->compu
Elemets->computationMethod->feature(PhyscompuInternalTo)->compu
I need to create the container compu with different features.How to create compu in sirius.
Please help me in this
Attaching
  • Attachment: Capture.PNG
    (Size: 16.45KB, Downloaded 276 times)
Re: Container drop and container creation [message #1791427 is a reply to message #1790908] Fri, 29 June 2018 04:33 Go to previous messageGo to next message
Hello
Your purpose is to create instance of class so I make the supposition that you 've already defined the mapping and all what is needed to display your entities in a diagram.
Then you may use either ContainerCreation Tool to crate a new instance or Container Drop tool to display in your diagram an existing instance
You can read the documentation about container drop : https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#containers
Do not forget to add some model operations
For example, if your source selection is from the model explorer, just add a ChangeContext operation that do nothing (var:element)
You have some example of Container Drop tool here: https://github.com/eclipse/ecoretools/blob/master/org.eclipse.emf.ecoretools.design/description/ecore.odesign
Laurent
Re: Container drop and container creation [message #1841307 is a reply to message #1791427] Tue, 11 May 2021 14:34 Go to previous message
No Message Body
[Updated on: Tue, 11 May 2021 14:52] by Moderator
Previous Topic:How to check Ecore type of element using AQL?
Next Topic:Creating EOL services to be called from a Sirius model
Current Time: Sat Jul 26 11:46:58 EDT 2025
Powered by FUDForum. Page generated in 0.04470 seconds
