Home » Eclipse Projects » Eclipse Titan » Can not add Titan in Eclipse
Can not add Titan in Eclipse [message #1841212] Thu, 06 May 2021 11:40 Go to next message
I am trying to install Titan for ITS testsuites.
I have try two methods :
- compiled titan from source, compilation succeed and bin is present in an Install directory as explained in the installation guide
- installed titan using apt : sudo apt-get install eclipse-titan
But after that, when I start Eclipse, I don't see titan options anywhere.
In a previous version of a setup (done in 2017), I could import .tpd for creating my workspaces form ITS repository. But in my actual, I can't do that. Eclipse don't know anything about Titan.
I have try doing Help->New software in Eclipse but I don't know which path I have to indicate. I have try to indicate the Install directory, but an error occurs :
could not find file ..../Install
Maybe I am missing something.
What I want is to be able to import my .tpd file from ITS repo to automaticaly build my workspace.
Re: Can not add Titan in Eclipse [message #1841225 is a reply to message #1841212] Fri, 07 May 2021 02:47 Go to previous messageGo to next message
Hi Julien,
From what You have described here I think You do not have the Eclipse Titan Executor plugin installed. Please follow the instrunctions in this Installation Guide:
https://www.eclipse.org/downloads/download.php?file=/titan/Eclipse_installationguide.pdf
Please let uss know if it helped!
Lenard Nagy
Re: Can not add Titan in Eclipse [message #1841226 is a reply to message #1841225] Fri, 07 May 2021 02:51 Go to previous message
I was answering during your message : " my bad, I forgot to install the Eclipse plug-in".
Thanks anyway.
Julien
Previous Topic:Compiler Version could not be determined
Next Topic:Variables used in several .cfg files
Current Time: Sun Jul 20 20:57:02 EDT 2025
Powered by FUDForum. Page generated in 0.05485 seconds
