Home » Eclipse Projects » Eclipse Hawk » How to force hawk to follow package structure
How to force hawk to follow package structure [message #1841003] Fri, 30 April 2021 03:37 Go to next message
I'm using hawk as a source model in a transformation. I facing a difference between how 'plain' epsilon source model works and hawk as source model.
The example in attachment shows illustrates my problem. The rule definition:
rule aRule transform s: IN!company::Company to t : OUT!companyTab::CompanyTab {
	t.col1 = s.name + "_transformed_" + s.isHeadquarter;
works fine in plain epsilon, but not with hawk. If change 's: IN!company::Company' to 's: IN!Company' it works in both cases. Now, the first FQN complies with the model definition, hence I would expect to also work in hawk. Maybe I'm missing something...
Thank you for your help and kind regards
Re: How to force hawk to follow package structure [message #1841093 is a reply to message #1841003] Mon, 03 May 2021 13:07 Go to previous messageGo to next message
Hi Jo,
Yes, when using the `A::B` notation, Hawk currently only allows straight metamodel URIs to be used for `A` (for instance, `https://www.home.org/companyTab::CompanyTab` would work).
I'll see if we can make it so `packageName::type` also works.
Best,
Antonio
Re: How to force hawk to follow package structure [message #1841094 is a reply to message #1841093] Mon, 03 May 2021 13:15 Go to previous messageGo to next message
Hi Antonio
Thank you for the answer.
Kind regards.
Re: How to force hawk to follow package structure [message #1841095 is a reply to message #1841094] Mon, 03 May 2021 13:30 Go to previous messageGo to next message
Hi Jo,
No problem. I've got a merge request with the enhancement ready:
https://gitlab.eclipse.org/eclipse/hawk/hawk/-/merge_requests/8
Once it passes all tests, I'll merge it. It should be available within a few hours :-).
Best,
Antonio
Re: How to force hawk to follow package structure [message #1841112 is a reply to message #1841095] Tue, 04 May 2021 04:59 Go to previous messageGo to next message
Hi Jo,
packageName::typeName should work now on the latest interim version of Hawk (2.2.0-SNAPSHOT from Maven).
Best,
Antonio
Re: How to force hawk to follow package structure [message #1841150 is a reply to message #1841112] Wed, 05 May 2021 02:00 Go to previous message
Hi Antonio
Just tested with 2.2.0-SNAPSHOT and this problem is solved. Thank you.
Previous Topic:How to convert GraphNodeWrapper to EObject
Current Time: Wed Nov 05 14:18:32 EST 2025
Powered by FUDForum. Page generated in 0.04143 seconds
