Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » eclipse and cmake
eclipse and cmake [message #1840945] Thu, 29 April 2021 07:03 Go to next message
can cmake be intergated into eclipse?
exporting C++ everytime waste a lot of time. Now the 4diac ide can check the modified fb, that we can just click build, then export file to the target then build them by cmake can save a lot of time
[Updated on: Thu, 29 April 2021 07:04] by Moderator
Re: eclipse and cmake [message #1840981 is a reply to message #1840945] Thu, 29 April 2021 15:25 Go to previous messageGo to next message
if you are just adding or changing fbs you do not need run cmake and a make process is sufficient. Furthermore since 4diac 1.13.0 I think we have an option to generate a generic CMakeFile which will include automatically all c++ files in he directory for building. This should make your life easier. More is always good and we are happy for any contributions.
Furthermore we also have the dynamic type load with Lua. I know this is far from complete (please have a look in our bugzilla for allready reported known issues). But would be very happy for more testers and support for our Lua integration. Here on both sides: 4diac FORTE and 4diac IDE work is needed.
Re: eclipse and cmake [message #1840991 is a reply to message #1840981] Thu, 29 April 2021 22:49 Go to previous messageGo to next message
which option, i s that CMAKE_VERBOSE_MAKEFILE ?
Re: eclipse and cmake [message #1841004 is a reply to message #1840991] Fri, 30 April 2021 04:22 Go to previous messageGo to next message
No there is a checkbox in the FORTE Exporter.
Re: eclipse and cmake [message #1841005 is a reply to message #1841004] Fri, 30 April 2021 04:59 Go to previous messageGo to next message
overwriting without warning?
Re: eclipse and cmake [message #1841078 is a reply to message #1841005] Mon, 03 May 2021 05:57 Go to previous message
There should be a checkbox with generate CMakeList.txt. If it is not yet there it will come with 4diac IDE 1.14.0
Previous Topic:reset the ecc status to start
Next Topic:Logging Event Timing Data
Current Time: Wed Jul 30 21:54:53 EDT 2025
Powered by FUDForum. Page generated in 0.05489 seconds
