Home » Eclipse Projects » Eclipse Hawk » How to convert GraphNodeWrapper to EObject
How to convert GraphNodeWrapper to EObject [message #1840908] Wed, 28 April 2021 11:49 Go to next message
Given the following eol query:
Object res = queryEngine.query(indexer, "return Company.all;", null);
How can I convert the GraphNodeWrapper object into EObject. An example would be welcome.
Kind regards,
Re: How to convert GraphNodeWrapper to EObject [message #1840915 is a reply to message #1840908] Wed, 28 April 2021 13:26 Go to previous messageGo to next message
Hi Jo,
The EOLQueryEngine class is EMF-agnostic, as well as GraphNodeWrapper: you cannot directly turn GNWs into EObjects. Instead, you should use .localhawkmodel files to expose a Hawk graph as an EMF resource, if you are using a local Hawk running in the same JVM. If you are accessing a remote model through the Thrift API, you will need to use a .hawkmodel file instead. For details on how to create .localhawkmodel files, check this page:
https://www.eclipse.org/hawk/advanced-use/graph-as-emf/
I can set up an example if you provide more details of your use case. Are you using Hawk from a pure Java program, or from an Eclipse plugin?
Best,
Antonio
Re: How to convert GraphNodeWrapper to EObject [message #1840917 is a reply to message #1840915] Wed, 28 April 2021 15:01 Go to previous message
thank you very much!
Your answer put me on track. Looking at the documentation and at the generated '.localhawmodel' helped to figure out how to setup the resource:
		LocalHawkResourceImpl resource = new LocalHawkResourceImpl(URI.createURI("models"), indexer, false, patterns, patterns);
		resource.basicSetResourceSet(rs, null);
		resource.load(Collections.EMPTY_MAP);
Previous Topic:Queries to get deleted elements
Next Topic:How to force hawk to follow package structure
Current Time: Wed Nov 05 14:18:29 EST 2025
Powered by FUDForum. Page generated in 0.03298 seconds
