Eclipse Customize Perspective NullPointerException [message #1838480] |
Thu, 25 February 2021 20:11  |
Hey, when i click on the Customize Perspective option i get this Error log:
org.eclipse.core.commands.ExecutionException: Error executing 'org.eclipse.ui.window.customizePerspective': java.lang.NullPointerException: Cannot invoke "String.split(String)" because "elementId" is null
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:170)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:488)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:487)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:389)
at org.eclipse.ui.internal.handlers.LegacyHandlerService.executeCommand(LegacyHandlerService.java:366)
at org.eclipse.e4.ui.workbench.addons.perspectiveswitcher.PerspectiveSwitcher.lambda$13(PerspectiveSwitcher.java:665)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:84)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:252)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4026)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3626)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
Caused by: org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException: Cannot invoke "String.split(String)" because "elementId" is null
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:253)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:173)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:156)
... 34 more
Caused by: java.lang.NullPointerException: Cannot invoke "String.split(String)" because "elementId" is null
at org.eclipse.ui.internal.dialogs.cpd.CustomizePerspectiveDialog.getToolbarLabel(CustomizePerspectiveDialog.java:1393)
at org.eclipse.ui.internal.dialogs.cpd.CustomizePerspectiveDialog.createTrimBarEntries(CustomizePerspectiveDialog.java:2013)
at org.eclipse.ui.internal.dialogs.cpd.CustomizePerspectiveDialog.loadMenuAndToolbarStructure(CustomizePerspectiveDialog.java:1557)
at org.eclipse.ui.internal.dialogs.cpd.CustomizePerspectiveDialog.<init>(CustomizePerspectiveDialog.java:539)
at org.eclipse.ui.internal.WorkbenchWindow.createCustomizePerspectiveDialog(WorkbenchWindow.java:3163)
at org.eclipse.ui.internal.WorkbenchPage.editActionSets(WorkbenchPage.java:1934)
at org.eclipse.ui.internal.handlers.EditActionSetsHandler.execute(EditActionSetsHandler.java:38)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:283)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:97)
at jdk.internal.reflect.GeneratedMethodAccessor63.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 38 more
FUDForum. Page generated in 0.41195 seconds
