Unable to connect to Azure SQL database from Eclipse [message #1840390] |
Tue, 13 April 2021 17:47  |
I'm using Azure SQL instance for my project and from my old laptop i was able to connect to the Azure SQL server database from eclipse (with CISCO VPN connected to the Azure network). But recently I received a new laptop from office as the old one is corrupted. I installed SSMS and am able to connect to Azure SQL server. But I'm unable to connect to the same SQL server from eclipse IDE(2021-03).
I am getting the below exception
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: The TCP/IP connection to the host sql-XXXXXXX, port 1433 has failed. Error: "connect timed out. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.".
If my machine is having any firewall issues, then even from SSMS I would not be able to connect. Not sure what is wrong? I've been trying to fix this for past 1 week but no luck.
Appreciate if someone can throw some light on this one
FUDForum. Page generated in 0.07802 seconds
