Re: Element Based Edge in one editor across different metamodels [message #1840704 is a reply to message #1840662] |
Thu, 22 April 2021 04:56  |
From the screeshot, your Input edge mapping uses source and target mappings like Public Progress and Data Element which are from another diagram definition. This is not supported, a diagram instance will only display instances of mappings from its own definition.
The Sirius Specification Editor unfortunately allows to chose all elements from anywhere in the file when choosing a source/target mapping, but ideally it should restrict the choices to the current diagram definition.
You can either create copies of the Public Progress mapping (and others) inside the WFP diagram (but it's more work to maintain), or define in WFP mapping imports which point to the original definitions from the other diagram definition.
FUDForum. Page generated in 0.06601 seconds
