Re: how to import vc++ project in Eclipse IDE [message #1842489 is a reply to message #1842405] |
Mon, 21 June 2021 12:04   |
Hi Sir
Thanks for the response.
I gone through the sent links able to create a projects(vc++) in eclipse IDE and able to see results also.
>Not sure what you are trying to do.
I will tell you in detail:
I have a RTOS Application, which is developed in VC++(MFC )...
My job is : I need to check the code correctness of the Application(VC++), for this I have a another software,this software integrated with Eclipse IDE, to use the software I need to build the application in Eclipse IDE.
so I am facing difficulties to build my VC++ application in Eclipse IDE,After building the application I can check my code correctness also, the software will not work without building the Application.
I am able to build the Application in Visual studio 2010,now I am trying to build in Eclipse IDE(I installed Visual studio toolchain)...as you suggested we build it importing as a makefile, could you suggest me how to generate a makefile in visual stdio,
FUDForum. Page generated in 0.07395 seconds
