Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » can't export forte boot file in 1.13.1(can't export forte boot file in 1.13.1)
can't export forte boot file in 1.13.1 [message #1840476] Fri, 16 April 2021 02:37 Go to next message
environment: 4diac ide: 1.13.1
in 4diac ide 1.13.1,i can't export forte boot file.
My steps are as follows:
1.right click on my project and chose 'export'
2.in 'explort' screen,chose 4diac IDE->Create FORTE boot-files->Next
3.in 'Create FORTE Boot-files' screen,click 'Browse' to chose directory
then there's nothing i can do,and the 'Filish' butten is disabled.I don't know if anyone else has a similar problem?
Re: can't export forte boot file in 1.13.1 [message #1840478 is a reply to message #1840476] Fri, 16 April 2021 02:54 Go to previous messageGo to next message
hi,
yes this is a known problem, which has been reported already several times in the forum. Also a bug has been added to our bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=568326
Re: can't export forte boot file in 1.13.1 [message #1840480 is a reply to message #1840478] Fri, 16 April 2021 03:17 Go to previous messageGo to next message
will the bug be fixed in the next release?
Re: can't export forte boot file in 1.13.1 [message #1840495 is a reply to message #1840480] Fri, 16 April 2021 09:57 Go to previous messageGo to next message
We try our best, but I want promise it. As strange as it may sound it is more work then it looks. The reason is the change of project layout which was introduced in 1.13.0. While it made many things much easier a few things got really hard. Boot-file exporter is one of them.
Definitely it will be fixed in 1.14.1.
Re: can't export forte boot file in 1.13.1 [message #1840513 is a reply to message #1840495] Fri, 16 April 2021 21:39 Go to previous messageGo to next message
Alois Zoitl wrote on Fri, 16 April 2021 13:57
good to know!
Then can we build the project in 1.13 and export the boot file in 1.12? we haven't tried it but we need a temporary solution as one of our project on site need the boot file to deal with the computer reboot or something like that.
Tibalt
Re: can't export forte boot file in 1.13.1 [message #1840544 is a reply to message #1840513] Sun, 18 April 2021 14:59 Go to previous messageGo to next message
first of all it should be possible to open 4diac 1.13 projects in 1.12.
However after having the first idea of a solution last week I finally found some time today to try it out. A first version of a fixed boot file generation can be found here: https://git.eclipse.org/r/c/4diac/org.eclipse.4diac.ide/+/179473
My first tests worked. But I would be happy to get more feedback.
Re: can't export forte boot file in 1.13.1 [message #1841744 is a reply to message #1840544] Thu, 27 May 2021 06:22 Go to previous messageGo to next message
thanks for your patch!
We moved everything into 1.12 again after everything done in 1.13. It is a pity but we have to fix it before we leave.
Now we have moved to 1.14 and the export of fboot works well.
Tibalt
Re: can't export forte boot file in 1.13.1 [message #1841751 is a reply to message #1841744] Thu, 27 May 2021 10:40 Go to previous message
You are welcome. Happy that we could finally fix that issue in 4diac IDE.
Previous Topic:FIXED --- Issue with QX and IX function blocks on Raspberry Pi OS
Next Topic:composite fb can't be watched in 1.14 ide
Current Time: Wed Jul 30 18:49:56 EDT 2025
Powered by FUDForum. Page generated in 0.29654 seconds
