Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » IEC 61499 Programming Standard: Will it Become Mainstream?:(Article to provoke industry discussion & thought)
IEC 61499 Programming Standard: Will it Become Mainstream?: [message #1840459] Thu, 15 April 2021 13:47 Go to next message
I recently published an article to provoke industry discussion & thought about IEC 61499. I use the word provoke because many times to change the status quo you need to elicit emotions to eventually get to broader rational discussion.
I'm interested in comments regarding the points I bring up in the article.
IEC 61499 Programming Standard: Will it Become Mainstream?: https://www.automation.com/en-us/articles/april-2021/iec-61499-programming-standard-become-mainstream
Thank you,
Bill Lydon
https://www.linkedin.com/in/blydon/
Re: IEC 61499 Programming Standard: Will it Become Mainstream?: [message #1840467 is a reply to message #1840459] Thu, 15 April 2021 17:04 Go to previous messageGo to next message
Thank you Bill,
Your article and discussion with Alois is enlightening. I am currently finishing my doctoral studies, which have focused on fault-finding for IEC 61499 systems using multi-agent approaches. During that time, I have worked with a number of different IEC 61499 development platforms.
For me, the one thing that has stood out is the depth of the 4diac/FORTE community. Alois and his team put so much time into supporting 4diac users. That is genuinely appreciated around here. That makes a huge difference to those of us who are working out how to design and deploy IoT systems that are robust and can be verified formally. I came previously from a world of development for automation where hacking together C/C++ code with little rigor and verification predominated. Working in IEC 61499 using 4diac is demanding, but I am learning how to deliver robust applications that I believe will stand up to the demands of safety-critical certification. That's the next area beyond my doctoral work that I want to head into; large IEC 61499 systems and formal safety evaluation methods. I think that being able to meet standards such as DO-178C for the aerospace industry is challenging for IEC 61499, but the framework has tremendous potential to address the obstacles involved. In my AUT SERL laboratory, we have an emphasis on formal methods and IoT security. Security for IEC 61499 should be a primary focus for many academic and industry practitioners going forward. From what I observe here, I think 4diac has a road map which is taking these issues seriously.
Unfortunately, that level of support is not evident for the other IEC 61499 development platforms and in other communities. In the long term, I think it will be community support and collaboration that is going to drive the adoption of IEC 61499. So thank you Alois, your team, and the 4diac community - I think things around here are definitely going in the right direction.
I look forward to talking with you further Bill.
Kind regards,
Badger Dowdeswell.
https://academics.aut.ac.nz/barry.dowdeswell
[Updated on: Fri, 16 April 2021 01:26] by Moderator
Re: IEC 61499 Programming Standard: Will it Become Mainstream?: [message #1840475 is a reply to message #1840459] Fri, 16 April 2021 02:08 Go to previous messageGo to next message
OK. The two urls are the same. :)
We now actively using 61499 in cement industial control applications. We got lots of help here and we offered some patches too. The community leadying by Prof AZ( Nick name we give to ‪Professor Alois Zoitl ) is great.
The reason we prefer 4diac to other iot projects(for example nodered) is that 4diac considered real time application at the beginning. In the industrial world, you have to consider real time as that is a base for almost all customer requirements.
I hope we can walk with 4diac for another 15 years. :)
Tibalt
Re: IEC 61499 Programming Standard: Will it Become Mainstream?: [message #1840545 is a reply to message #1840475] Sun, 18 April 2021 15:46 Go to previous messageGo to next message
Dear Barry, Dear Tibalt,
thanks a lot for your kind words. This community thinking was what we hoped for when we had the first idea of an open source environment for IEC 61499 back in 2006. It seems we are getting there. Great!
@Barry: just recently I had a discussion about the possibility of IEC 61499 compared to C/C++. And although IEC 61499 with its integration of IEC 61131-3 (in 4diac mostly Structured Text) is partly quite limiting, it has some advantages because some errors can not be made. Therefore we think it should be easier to write more correct code. But also interested in your opinion.
@Tibalt: I find it very interesting that you choose us over nodered. We are sometimes compared to it.
BR,
Alois
PS: I like the nick name ;-)
Re: IEC 61499 Programming Standard: Will it Become Mainstream?: [message #1840627 is a reply to message #1840545] Tue, 20 April 2021 23:26 Go to previous messageGo to next message
Hi Alois,
I also like the nickname "Prof AZ" too.. but we must be careful or else it will catch on with your students :)
Thank you for asking for my opinion on this. C++ has some tremendous advantages over Structured Text in environments like 4diac/FORTE if engineers are willing to take the time to learn it. You will see in recent posts from me that I have been interfacing sensors to REAL hardware as part of the final experimental phase of my doctoral research. However, the driver code for the temperature sensors such as the DS18B20 I am using could not be written easily in Structure Text (at least I could not see how to do it ... ).
In hindsight, learning C++ under C:++11 was so much easier than I expected since many of the constructs are much closer to all my Java experience; C has come a long way by the time we got to C++11 in 2021 !!!! Also, learning C++ allowed me to be much more confident about diving down into the core of FORTE. That taught me so much about how it worked. Sometimes when I was stuck trying to code something, I would run a search on the core library to find a function that I could learn from. That's how I found out how to print CIEC_STRING variables out with cout : there is a getValue() method on CIEC_STRING that I had not found before. That means when debugging, I can compile in all the console messages I need. While the FBTester is a great tool, it is not enough when trying to debug a complex set of interactions across multiple blocks. Real embedded programmers have to work down on the bare metal some times !!!!
Also, I can control casts properly to ensure that in some of the complex maths we are doing inside events, we get the correct precision. Again, that could be problematic in Structured Text.
During my Post-doctoral that starts in a few months time, I intend to start writing some tutorial guides for 4diac/FORTE including using C++ routines . Professor Roopak Sinha and I have discussed this as an option for me. We feel it would be useful for both our students here at AUT that we want to introduce 4diac to, and for the 4diac community at large. Also, I am interested in documenting more examples of getting sensors and actuators going on platforms such as Raspberry Pi and the WAGOs we have in our AUT laboratory. Again, all this is just a little part that helps to foster the collaboration that you and your team have facilitated Prof AZ.
Barry
Re: IEC 61499 Programming Standard: Will it Become Mainstream?: [message #1840671 is a reply to message #1840627] Wed, 21 April 2021 15:53 Go to previous message
Hi Barry,
thanks for you long an insightful post. Yes I agree that in several situations currently it is still necessary to debug 4diac FORTE or your FBs in C++. I really hope that this will not be needed in the future. There are some activities in that direction. We will keep the community updated.
Also there will be quite some improvements in our overall ST support. Hopefully we already have something for the autumn release.
Alois
Previous Topic:Watch Values in own application results in TCP reset
Next Topic:reset the ecc status to start
Current Time: Wed Jul 30 23:31:45 EDT 2025
Powered by FUDForum. Page generated in 0.41539 seconds
