Home » Modeling » TMF (Xtext) » Formatter2 autowrap
Formatter2 autowrap [message #1840454] Thu, 15 April 2021 12:31 Go to next message
Is there some trick to enable autowrap? It doesn't seem to work even with a simple DSL:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
	definitions+=VariableDefinition*
	eval=Expression;
VariableDefinition:
	name=ID ('(' parameter=ID ')')? '=' value=Expression;
Expression:
	FeatureCall | Literal;
Literal:
	literal=Boolean;
FeatureCall:
	target=[ecore::EObject|ID] ('(' argument=ID ')')?;
Boolean returns ecore::EString:
	'true' | 'false'
And its formatter:
class MyDslFormatter extends AbstractFormatter2 {
	@Inject extension MyDslGrammarAccess
	def dispatch void format(Model model, extension IFormattableDocument document) {
		model.definitions.forEach[format]
	def dispatch void format(VariableDefinition it, extension IFormattableDocument document){
		val extension access = variableDefinitionAccess
		regionFor.keyword(equalsSignKeyword_2).prepend[oneSpace].append[oneSpace autowrap]
Given this, the following test fails:
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslFormattingTest {
	@Inject
	extension FormatterTestHelper
	@Test
	def void loadModel() {
		assertFormatted[
			request.preferences = new MapBasedPreferenceValues => [
				put(FormatterPreferenceKeys.maxLineWidth, 31)
			toBeFormatted = '''
				myThing = longggggggggggggggggggggggggg
				myThing
			expectation = '''
				myThing =
				myThing
Maybe I'm missing something but the only documentation I could find was these slides and it looks like this should work.
Re: Formatter2 autowrap [message #1840466 is a reply to message #1840454] Thu, 15 April 2021 16:52 Go to previous messageGo to next message
you need some formatting after the stuff that should be autowrapped.
(am not sure if this is a bug or feature. so you may try
val kw = regionFor.keyword("=")
kw.prepend[oneSpace]
kw.append[autowrap; oneSpace]
append[newLine]
Re: Formatter2 autowrap [message #1840490 is a reply to message #1840466] Fri, 16 April 2021 07:53 Go to previous messageGo to next message
This definitely looks like a bug to me. What is considered "after the stuff that should be autowrapped" though? Is it at the end of the model element specifically, or on the next hidden region? In my real DSL, I have plenty of formatting "after the stuff that should be autowrapped", it just happens in the next semantic element, for example if we change it to:
Expression:
	Addition;
Addition:
	Primary ({Addition.left=current} '+' right=Primary)*;
Primary:
	append[newLine]
def dispatch void format(Addition it, extension IFormattableDocument document) {
	val extension access = additionAccess
	regionFor.keyword(plusSignKeyword_1_1).prepend[oneSpace autowrap].append[oneSpace]
	append[newLine]
assertFormatted[
	toBeFormatted = '''
		myThing = thing + longggggggggggggggggggggggggg + another
		myThing
	expectation = '''
		myThing =
		thing
		+ another
		myThing
This works for the autowrap at the equals sign, but there's no further autowrap at the + sign. I would have actually expected a forced line break before the second + in that test since I put append[newLine] on the Addition.
Re: Formatter2 autowrap [message #1840491 is a reply to message #1840490] Fri, 16 April 2021 08:11 Go to previous messageGo to next message
see
org.eclipse.xtext.formatting2.internal.FormattableDocument.createReplacements(ITextReplacerContext)
please debug there for differences
the autowrap happens only if there is something to format after the autowrap position
i dont know why. moritz is no longer active with Xtext
[Updated on: Fri, 16 April 2021 08:13] by Moderator
Re: Formatter2 autowrap [message #1840577 is a reply to message #1840491] Mon, 19 April 2021 12:37 Go to previous message
The clue was in the missing forced line break before the second +, since I had forgotten to actually format the child expressions.
It looks like the "formatting after the stuff that should be autowrapped" is only needed if there is no other semantic element after "the stuff" instead.
The workaround I've settled on is putting append[lowPriority noSpace] on my top level element:
	append[lowPriority noSpace] // this is the workaround
This seems to enable the autowrap in all contained elements as suggested, and is unlikely to conflict with some trailing formatting that might be present on the last expression in the file.
Previous Topic:Bind STRINGValueConverter
Next Topic:Xtext LSP, Client with separate server process
Current Time: Sun Aug 31 03:18:54 EDT 2025
Powered by FUDForum. Page generated in 0.03923 seconds
