Home » Eclipse Projects » Marketplace Client Project » How to disable HTTP Marketplace with Proxy(Eclipse IDE Proxy / Marketplace Settings)
How to disable HTTP Marketplace with Proxy [message #1840330] Mon, 12 April 2021 13:38 Go to next message
I'm trying to setup Eclipse IDE using an Native proxy setting or manually using a HTTP proxy but the Eclipse Marketplace keeps forcing HTTPS and not getting past our SSL inspection.
Obeo & Red Hat marketplaces both load using both proxy methods above, only Eclipse's marketplace doesn't load.
I cannot seem to find anyway to force HTTP or disable HTTPS via the eclipse.ini or any options inside the application.
Re: How to disable HTTP Marketplace with Proxy [message #1840389 is a reply to message #1840330] Tue, 13 April 2021 17:16 Go to previous message
Why do you think you need to disable it? Are you getting SSL certificate errors? That sounds like you need to install a root certificate for your proxy in the jvm running Eclipse.
Previous Topic:Can't install an extension from the market
Next Topic:Blocking an install on a particular eclipse release
Current Time: Wed Jul 30 15:31:54 EDT 2025
Powered by FUDForum. Page generated in 0.03753 seconds
