Home » Eclipse Projects » Memory Analyzer » Leak Suspect Report makes huge file(I wanted to make a Leak Suspect Report of a hprof file and got an html file which filled my SSD whoch)
Leak Suspect Report makes huge file [message #1839802] Mon, 29 March 2021 06:10 Go to next message
I was about to analyse a heap dump from my Moded Minecraft Server and the Leak Suspect Report never finished loading and I had to stop the programm caus my SSD was out of storage, becaus of the huge html file it produced.
Here you can see it in WinDirStat
index.php/fa/40238/0/
I used the standalone installation of Eclipse Memory Analyzer and got the Version 1.11.0
Uh and I cant uploade the hprof file becaus its 4 GB, but I will find a way to share it if necessary (which makes sense).
Also I made another heap dump of the same Server and with that one everything was fine. So it has to be a special problem with this particular dump I guess.
  • Attachment: Huge Size.PNG
    (Size: 1.23MB, Downloaded 1138 times)
Re: Leak Suspect Report makes huge file [message #1839887 is a reply to message #1839802] Wed, 31 March 2021 03:07 Go to previous messageGo to next message
That huge file is not right.
Is there a way you can extract the first part of the huge file ? You will need to delete one of those huge report directories so you have some free disk space and then run, for example, from PowerShell:
gc -Delimiter ">" -TotalCount 50000 .\28.html >28short.html
We can then see which part of the report is so big.
If you can compress the HPROF file (with zip, gzip etc. or in Windows send it to a compressed folder) then that might make the file more manageable to upload somewhere.
Re: Leak Suspect Report makes huge file [message #1839896 is a reply to message #1839887] Wed, 31 March 2021 06:19 Go to previous messageGo to next message
So I already deletet the hug files, but I made a new one with about 3 GB (I stopped the program there, should be enough I guess), compressed it to zip and also compressed the heap dump, which rly helped alot (why didn't I think about that) and uploaded both to
Dropbox: https://www.dropbox.com/sh/8pyvix1m7p86qf2/AAA6sGby2CIbiMC84weHMOWna?dl=0
Thank you so far.
Re: Leak Suspect Report makes huge file [message #1839903 is a reply to message #1839896] Wed, 31 March 2021 10:28 Go to previous messageGo to next message
Thanks. I think I have an idea what has gone wrong.
It is in 'Thread Stack and Involved Local Variables' where a tree is being continually expanded.
It is meant to show the thread, which is expanded to show the stack frames, and the the stack frames which have a reference to the leaking object, but the objects are being expanded too.
I have opened a bug:
572491: Leak Suspect Report makes huge file
Re: Leak Suspect Report makes huge file [message #1839905 is a reply to message #1839903] Wed, 31 March 2021 11:43 Go to previous messageGo to next message
Okay, interesting. This was also the heapdump I suspected Memory Leak (caus my Minecraft server ran out of Memory). Sorry I am more or less a noob, how do I search now for the leak, would be great if you know any good advice.
Thanks.
Re: Leak Suspect Report makes huge file [message #1839950 is a reply to message #1839905] Thu, 01 April 2021 17:13 Go to previous messageGo to next message
I have made a fix. Please try a snapshot build to see if it fixes the problem with Memory Analyzer.
Re: Leak Suspect Report makes huge file [message #1840050 is a reply to message #1839950] Tue, 06 April 2021 03:46 Go to previous messageGo to next message
Yes it is fixed, no more huge files, thank you.
Re: Leak Suspect Report makes huge file [message #1843080 is a reply to message #1840050] Wed, 14 July 2021 09:59 Go to previous message
It all works for me) thank you)
Previous Topic:Mat Linux Command Line Usage with Discard Feature
Next Topic:HTML Report
Current Time: Sat Aug 30 19:31:25 EDT 2025
Powered by FUDForum. Page generated in 0.03999 seconds
