Home » Language IDEs » Java Development Tools (JDT) » [Help] (SWT:5152): Gtk-WARNING ?
[Help] (SWT:5152): Gtk-WARNING ? [message #1839880] Tue, 30 March 2021 22:59 Go to next message
Hi all,
using eclipse kepler (java SWT) on Ubuntu 12.04 a long time.
try to use eclipse 2021.03 (java SWT) on Ubuntu 20.04-1,
got a error message, like below
SWT:5152): Gtk-WARNING **: 17:07:35.445: Negative content width -16 (allocation 1, extents 8x9) while allocating gadget (node button, owner GtkButton)
(SWT:5152): Gtk-WARNING **: 17:07:35.445: Negative content height -8 (allocation 1, extents 4x5) while allocating gadget (node button, owner GtkButton)
(SWT:5152): Gtk-WARNING **: 17:07:35.446: Negative content width -16 (allocation 1, extents 8x9) while allocating gadget (node button, owner GtkButton)
can someone know how to solve it ?
Thanx a lot.
Re: [Help] (SWT:5152): Gtk-WARNING ? [message #1839912 is a reply to message #1839880] Wed, 31 March 2021 16:09 Go to previous messageGo to next message
That is not an error, it is a warning. If you're not running into symptoms that are causing problems, I would ignore it.
Re: [Help] (SWT:5152): Gtk-WARNING ? [message #1839918 is a reply to message #1839912] Thu, 01 April 2021 03:12 Go to previous messageGo to next message
Kepler is very old so if you want to run Kepler-vintage Eclipse you should use a Kepler-vintage Java and OS.
I had related problems with compatibility builds on one of the older EF build clusters. The IT team tried to upgrade/patch the Centos OS and things steadily went from poor to bad to worse. Bottom line do not mix and match with a non-trivial mis-match. At worst you get major failures, at best you get warnings about potential failings.
Ed Willink
Re: [Help] (SWT:5152): Gtk-WARNING ? [message #1839928 is a reply to message #1839918] Thu, 01 April 2021 07:18 Go to previous messageGo to next message
ya, kelper is very old, try to use newest version, but got warm messages, dont know how is going on...
Re: [Help] (SWT:5152): Gtk-WARNING ? [message #1839929 is a reply to message #1839912] Thu, 01 April 2021 07:20 Go to previous messageGo to next message
It seems my prodgram is something wrong, need to find it out. 3Q
Re: [Help] (SWT:5152): Gtk-WARNING ? [message #1840022 is a reply to message #1839929] Mon, 05 April 2021 06:20 Go to previous messageGo to next message
My program is also worng. How can i solve it?
Re: [Help] (SWT:5152): Gtk-WARNING ? [message #1840027 is a reply to message #1840022] Mon, 05 April 2021 10:43 Go to previous message
Hope u figure if out . and tell me why? Thanx.
Previous Topic:The workspace exited with unsaved changes in the previous session; refreshing workspace to recover c
Next Topic:Exporting Old Version
Current Time: Sat Jul 26 03:59:56 EDT 2025
Powered by FUDForum. Page generated in 0.06639 seconds
