JS - Java questions [message #1839827] |
Mon, 29 March 2021 11:26  |
Hello..
I am diving in JS development.. I managed to show heatmap field, send events to Java using this.trigger and this.send method and catch events in handleUiEvent in JsonHeatmapField.. Now I would like to create component on my own and have some questions.
1. How to trigger event from Java to JS?
I saw that some events can be catched on adapter in onModelAction method? Is that right?
Also do I need to create facade class when sending events from browser JS to Java?
2. Where is best to init jQuery plugin on MyField.js, on render method or init or somewhere else? How to include jQuery plugin that is not using es6 module structure? Do I need to include jQuery also? Some example?
3. _renderMyProperty is called every time when property is set in Java. But when property has same value, render is not triggered. How to force it to trigger? Is setPropertyAlwaysFire an option?
4. I am trying to create text editor component using some jquery plugin like summernote.
I need to extends AbstractValueField, create field with some class and init plugin, right? Can you show example how to init and include jquery plugin?
StringField.js is best example to follow in order to make text editor field, right?
Thank you
FUDForum. Page generated in 0.21542 seconds
