Home » Modeling » TMF (Xtext) » Customize Scoping for inheritance
Customize Scoping for inheritance [message #1839773] |
Sun, 28 March 2021 07:53  |
Hi all,
I have the following grammar in Xtext where Countries extend Countries. By that I want to support inheritance. The following is my grammar and afterwards I will be showing some examples of what I want to achieve.
grammar org.xtext.example.forest.Forest with org.eclipse.xtext.common.Terminals
generate forest "http://www.xtext.org/example/forest/Forest"
Country:
"country" name=ID ("extends" supercountry=[Country|QualifiedName])?
forests=Forest
Forest:
name=ID
("tree" trees+=Tree ("," trees+=Tree)*)*
("house" houses+=House ("," houses+=House)*)*
("remove" remove=[Tree|QualifiedName])?
("remove" remove=[House|QualifiedName])?
Tree:
name=ID
House:
name=ID
QualifiedName:
ID ('.' ID)*
The example is as follows:
file1.dsl
country C1 {
forest {
tree T1, T2;
house H1, H2;
file2.dsl
country C2 extends C1 {
forest {
remove T1;
remove H2;
I want to customize the Scope Provider so that when I say country C2 extends C1, I will get suggestions only from C1 (because if I were to work with the Default Scope Provider and I would have a third file with Country C3, I would get suggestions from there too which I do not want).
I also tried the approach of using imports, but that doesn't work well for me either. I have been trying to find examples on how to customize this scope provider to achieve what I want but I have not been able to.
Your help is highly appreciated.
Thanks!
Re: Customize Scoping for inheritance [message #1839810 is a reply to message #1839801] |
Mon, 29 March 2021 06:55   |
Okay, so I might have misdirected you, but this is what I want to do with an example.Note that these are three different files in one project.
file1.dsl
country C1 { forest F1
tree T1, T2
house H1, H2
file2.dsl
country C2 { forest F2
tree T3, T4
house H3, H4
file3.dsl
country C3 inherits C2 { forest F3
tree T5, T6
house H5, H6
remove T3 //here I should only get suggestions for T5, T6 which are part of C3, and T3,T4 which are inherited from C2. However, with the scope provider snippet that I have, I still get suggestions even for T1, and T2 which are part of C1 and I dont want that.
I understand that the code snippet I already have might be wrong, but I would very much appreciate your help as I really need it for a project.
Many thanks!
Re: Customize Scoping for inheritance [message #1839861 is a reply to message #1839819] |
Tue, 30 March 2021 09:52   |
Hi Christian,
I am currently working on customizing the scope provider for my grammar, and it works for most of it. However, I have issues in a specific case.
So being that Xtexts' default scope provider allows you to reference elements from all the files that are part of the same project by using the qualified name, I want to restrict that. I removed the qualified name but with the following grammar and the following scope provider I am not able to refer to trees specified in country which I am extending.
This is the grammar:
Country:
forests=Forest
Forest:
"forest" name=ID
("workingArea" position+=Position)*
Tree:
name=ID
Position:
name=ID "from" from=[Tree] "to" from=[Tree]
House:
name=ID
QualifiedName:
ID ('.' ID)*
These are the examples:
file1.forest
tree T1, T2
file2.forest
forest F2
tree T7
workingArea area from T7 to T7 //here I also want to be able to refer to T1, and T2, but I can't.
This is a snippet of my scope provider. The second part else if, is what I am trying to implement to make this possible, but I can't seem to get it right.
public class ForestScopeProvider extends AbstractForestScopeProvider {
public IScope getScope(EObject context, EReference reference) {
if (reference == ForestPackage.Literals.FOREST__REMOVE) {
Country rootCountry = (Country) EcoreUtil2.getRootContainer(context);
List<EObject> treesAndHouses = new ArrayList<>();
while (rootCountry != null) {
treesAndHouses.addAll(rootCountry.getForests().getTrees());
treesAndHouses.addAll(rootCountry.getForests().getHouses());
rootCountry = rootCountry.getSupercountry();
System.out.println(treesAndHouses);
return Scopes.scopeFor(treesAndHouses);
else if (reference == ForestPackage.Literals.FOREST__POSITION) {
List<EObject> position = new ArrayList<>();
position.addAll(rootCountry.getForests().getPosition());
System.out.println(position);
return Scopes.scopeFor(position);
return super.getScope(context, reference);
Thank you!
Re: Customize Scoping for inheritance [message #1839947 is a reply to message #1839862] |
Thu, 01 April 2021 13:24   |
Hi Christian,
I am trying to access a specific element from my grammar and I have been trying for a while but no luck.
Country:
forests=Forest
Forest:
"forest" name=ID "{"
"subforest" subforest+=Subforest
Tree:
name=ID
Position:
name=ID "from" from=[Enter] "to" to=[Exit]
House:
name=ID
Subforest:
name=ID
"enter" enter+=Enter
"exit" exit+=Exit
Enter:
name=ID
Exit:
name=ID
QualifiedName:
ID ('.' ID)*
And this is my scope provider:
if (reference == ForestPackage.Literals.POSITION__FROM) {
position.addAll(rootCountry.getForests(). getSubforest());
I want to be able to access Enter and Exit so the position will be from enter to exit. Both enter and exit are contained by a subforest, but when I write this line in my scope provider:
I cannot go further than getSubforest() , while I have the idea that in order to access enter and exit I should be able to write
position.addAll(rootCountry.getForests(). getSubforest().getEnter());
position.addAll(rootCountry.getForests(). getSubforest().getExit);
Re: Customize Scoping for inheritance [message #1839976 is a reply to message #1839974] |
Fri, 02 April 2021 10:44   |
It works for this case, but for a more complex case like the following it doesnt:
Country:
forests=Forest
Forest:
("park" parks+=Park ("," parks+=Park)*)*
"workingarea" workingarea=WorkingArea
Park:
name=ID ("{"
"exit" exit+=Exit
WorkingArea:
name=ID "from" from=[ParkEnter] "to" to=[ParkExit]
Enter:
Name=ID
Exit:
Name=ID
ParkEnter:
Park | Enter
ParkExit:
Park | Exit
QualifiedName:
ID ('.' ID)*
And this is the scope provider:
if (reference == ForestPackage.Literals.WORKING_AREA__FROM) {
List<EObject> workingarea = new ArrayList<>();
for (Park park :rootCountry.getForests().getParks()){
workingarea.addAll(park.getEnter());
workingarea.addAll(rootCountry.getForests().getParks());
System.out.println(workingarea);
return Scopes.scopeFor(workingarea);
else if (reference == ForestPackage.Literals.WORKING_AREA__TO) {
List<EObject> workingareato = new ArrayList<>();
workingareato.addAll(park.getExit());
workingareato.addAll(rootCountry.getForests().getParks());
System.out.println(workingareato);
return Scopes.scopeFor(workingareato);
However, if I try to write this example I cannot. I have put some comments in the grammar to show what is wrong.
country C1 {
forest F1 {
park P1 {
enter Enter1
exit Exit1
park P2
workingarea W1 from P1 to P1 \\here I want to be able to say from and to P1, Enter1,Exit1, P2 , but I am only allowed to say P1
park P3 {
enter Enter2
exit Exit2
park P4
workingarea W2 from P1 to P3 \\here I want to be able to say from and to P1, Enter1,Exit1, P2 ,P3,Enter2,Exit2 and P4 but I am only allowed to say P1 and P3.
Many thanks!
Re: Customize Scoping for inheritance [message #1839984 is a reply to message #1839980] |
Fri, 02 April 2021 16:50   |
Ok, the grammar should work fine now. I changed Enter: name=ID but I cannot change Exit too because I get :
There cannot be two features named "name".
Country:
"country" name=ID ("extends" supercountry=[Country|QualifiedName])? "{"
forests=Forest
Forest:
("workingarea" workingarea=WorkingArea)*
Park:
name=ID ("{"
"exit" exit+=Exit
WorkingArea:
Enter:
name=ID
Exit:
Name=ID
ParkEnter:
Park | Enter
ParkExit:
Park | Exit
QualifiedName:
ID ('.' ID)*
This is the example and there are comments there to explain what I need:
country C1 {
forest F1 {
park P1 {
enter EN1
exit EX1
park P2 {
enter EN2
exit EX2
park P3
park P4 {
enter EN3
exit EX3
park P5
workingarea W4 from EN1 to P2 //need to have from: P5, P4.EN3 to: P5,P4.EX3 because P4 only contains P4.EN3,P4.EX3 and P5
workingarea W2 from EN1 to P2 //need to have from: P2.EN2, P3, P4, P4.EN3 to: P2.EX2, P3, P4,P4.EX3 because P2 contains P2.EN2, P2.EX2, P3, P4, P4.EN3 and P4.EX3. Contrary to others, here we have two parks contained in one park therefore we also allow P3 and P4, not only P4.EN3 and P4.EX3
workingarea W1 from EN1 to P2 //need to have from: P1.EN1 to: P1.EX1
park P6 {
enter EN4
exit EX4
workingarea WF from EN4 to P6 // here I currently have from: EN1, EN4,P1,P2,P6 . I should not have P2 , I should only have P1, P6, P1.EN1,P6.EN4. To should be: P1.EX1, P6.EX4, P1,P6
So to summarize each working area that belongs to a park, should allow cross referencing enter and exit of that same park, sub parks of that park and the corresponding enter and exit. However, the current scope provider only allows to cross reference park P1, park P6 and their corresponding enter and exit (EN1,EX1,EN4,EX4) but not their sub parks and corresponding enter and exit (it allows the same thing throughout the entire grammar).
For the forest, I should not have P2, because it is a subpark of P1. I should only have P1, P6 and their corresponding enter and exit.
Hope this isn't too complex.
This is the scope provider.
workingarea.addAll(park.getParks());
workingareato.addAll(park.getParks());
I think the current scope provide only collects the first (P1, P6) and second (P2) level of parks and their respective enter and exit points, but it does not go deeper than that, while in my case I guess I have to check until there are no more parks.
Many thanks!
[Updated on: Fri, 02 April 2021 18:50] by Moderator
Re: Customize Scoping for inheritance [message #1840102 is a reply to message #1840095] |
Tue, 06 April 2021 16:40   |
I tried out the following scope provider where instead of :
I put
List<ParkEnter> workingarea = new ArrayList<ParkEnter>();
Because I couldn't say :
return Scopes.scopeFor(workingarea, (ParkEnter e) -> {
Park p = (Park) e.eContainer();
return QualifiedName.create(p.getName(), e.getName());
}, IScope.NULLSCOPE);
Being that I already had declared a working area.
This is the scope provider that I am using:
// List<EObject> workingarea = new ArrayList<>();
workingarea.addAll(EcoreUtil2.getAllContentsOfType(rootCountry, ParkEnter.class));
But I do not get any suggestions when I try to write the grammar
Re: Customize Scoping for inheritance [message #1840129 is a reply to message #1840116] |
Wed, 07 April 2021 04:29   |
Hi Christian,
Sorry for all the hustle.
I tried your approach, but first on this line:
Function<ParkEnter, QualifiedName> nameComputation = (ParkEnter e) -> {
I got an error saying:
Multiple markers at this line
- The target type of this expression must be a functional
interface
- Function cannot be resolved to a type
So I imported com.google.common.base.Function
However afterwards I got an error on this line:
return Scopes.scopeFor(workingarea, nameComputation, IScope.NULLSCOPE);
saying:
- The method scopeFor(Iterable<? extends T>, Function<T,QualifiedName>, IScope) in the type Scopes is not applicable for the arguments (List<EObject>,
Function<ParkEnter,QualifiedName>, IScope)
This is the full scope provider:
EObject eContainer = e.eContainer();
if (eContainer instanceof Park) {
Park p = (Park) eContainer;
return QualifiedName.create(e.getName());
Many thanks once again!
Re: Customize Scoping for inheritance [message #1840139 is a reply to message #1840130] |
Wed, 07 April 2021 05:58   |
Hi Christian,
Yes you are right that is why it is so hard for me to customize this scope provider. However I still get issues, maybe it is something related to the EObject e, because in row:
return QualifiedName.create(p.getName(),e.getName());
And in row
I get
- The method getName() is undefined for the type EObject
Which I would not get when there was ParkEnter instead of EObject.
Function<EObject, QualifiedName> nameComputation = (EObject e) -> {
Many thanks!
Re: Customize Scoping for inheritance [message #1840159 is a reply to message #1840153] |
Wed, 07 April 2021 15:58   |
Hi Christian,
I tried a few things with the grammar :
First I tried the following function:
if (e instanceof Park)
Park p = (Park) e;
return QualifiedName.create(p.getName(), ((Park) e).getName());
return QualifiedName.create(((ParkEnter) e).getName());
But here I get Park.Park and not Park.Enter () because of this line:
Afterwards I tried the following function:
if (e instanceof ParkEnter)
ParkEnter p = (ParkEnter) e;
return QualifiedName.create(p.getName(), ((ParkEnter) e).getName());
Here I get Park.Park and Enter.Enter being that ParkEnter: Park | Enter, but still I don't get Park.Enter
Now I am trying the following:
if (e instanceof Enter)
Enter en = (Enter) e;
return QualifiedName.create(Park.getName(), en.getName());
because I want to have Park.getName() , Enter.getName, but I don't really know how to access Enter, and the Park to which that Enter belongs to.
In this scope provider I get an error because
Cannot make a static reference to the non-static method getName() from the type
ParkEnter
I am including the grammar once again:
Country:
forests=Forest
Forest:
Park:
name=ID ("{"
WorkingArea:
name=ID "from" from=[ParkEnter|QualifiedName]
Enter:
name=ID
ParkEnter:
Park | Enter
QualifiedName:
ID ('.' ID)*
And the scope provider:
Park p = (Park) e;
Re: Customize Scoping for inheritance [message #1840192 is a reply to message #1840183] |
Thu, 08 April 2021 08:09   |
Hi Christian,
I was able to solve the issue that I had before, but now I was wondering about something else. With the following scope provider:
Park p = EcoreUtil2.getContainerOfType(en, Park.class);
return QualifiedName.create(p.getName(), en.getName());
return QualifiedName.create(((ParkEnter)e).getName());
I should use the qualified name even when I cross reference elements in the same hierarchical level. For example in the following grammar(please read the comment).
country C1 {
forest F1 {
park P1 {
enter EN1
park P2 {
enter EN2
park P3
park P4 {
enter EN3
park P5
workingarea W4 from P4.EN3. // here it should be EN3 because both EN3 and W4 are Part of P4. If I were to have EN2, that I should write it as P2.EN2, as it is not part of P4.
workingarea W2 from P2
workingarea W1 from P6.EN4
park P6 {
enter EN4
workingarea WF from P6.EN4
Is there a way around this?
Many thanks!
Current Time: Mon Jul 21 10:38:58 EDT 2025
Powered by FUDForum. Page generated in 0.37611 seconds
