Home » Eclipse Projects » Remote Application Platform (RAP) » FileUpload issue(FileUpload issue while uploading a file)
FileUpload issue [message #1839748] Sat, 27 March 2021 03:39 Go to next message
I'm building a rap application and I use a fileUpload widget.
I really simplified to code to understand what's happening.
Here is what I do
public class UploadHandler extends AbstractHandler {
	public static final String LOCAL_DEVICE_SHAPE_XMI_FILE = "localDeviceShapeXmiFile";
	public Object execute(ExecutionEvent event) throws ExecutionException {
		FileDialog fileDialog = new FileDialog(HandlerUtil.getActiveShell(event), SWT.OPEN);
		fileDialog.setFilterExtensions(new String[] { ".xmi" });
try {
		String file = fileDialog.open();
		MessageDialog.openInformation(HandlerUtil.getActiveWorkbenchWindow(event).getShell(), "Info",
				"Uploaded and stored here " + file);
}catch (Throwable e) {
	e.printStackTrace();
It's working perfectly when I start the application within eclipse
index.php/fa/40225/0/
Now I start the application outside eclipse(I packaged it as a war file and deploying in tomcat 9) and the upload part is not working ( Error 500)
index.php/fa/40227/0/
The error is :
Status Report : Message
The system cannot find the path specified
Description The server encountered an unexpected condition that prevented it from fulfilling the request
I'm running equinox with servlet bridge and the osgi bundles are well started
(when I type SS )
16 ACTIVE org.apache.commons.fileupload_1.3.2.v20170320-2229
58 ACTIVE org.eclipse.rap.fileupload_3.16.0.20210107-1425
59 ACTIVE org.eclipse.rap.filedialog_3.16.0.20210107-1310
I do not see errors in the osgi console
( I started my servlet in the web.xml with the following arguments like in eclipse )
<init-param>
<param-name>commandline</param-name>
<param-value>-console -consoleLog</param-value>
</init-param>
Can someone guide me to understand what's happening ?
  • Attachment: uploadOK.png
    (Size: 5.92KB, Downloaded 404 times)
  • Attachment: UploadNOK.png
    (Size: 54.24KB, Downloaded 404 times)
[Updated on: Sat, 27 March 2021 03:40] by Moderator
Re: FileUpload issue [message #1839751 is a reply to message #1839748] Sat, 27 March 2021 04:21 Go to previous messageGo to next message
When starting in debug mode In FileDialog.open
I'm having this error OS.FNERR_INVALIDFILENAME
( public static final int FNERR_INVALIDFILENAME = 0x3002; )
index.php/fa/40231/0/
  • Attachment: OSError.png
    (Size: 23.52KB, Downloaded 378 times)
Re: FileUpload issue [message #1839763 is a reply to message #1839751] Sat, 27 March 2021 17:26 Go to previous message
I was able to fix.
First my project was containing org.eclipse.swt bundle which was not the one to use. That's why the debug part was not showing the bundle org.eclipse.rap.FileDialog.
Then the temporary file seemed not to be set ( but set by eclipse that why it was working )
So I added
fileDialog.setUploadDirectory(new File(myDir));
Previous Topic:How to use nebula RichTextCellLabelProvider
Next Topic:Web Service on RAP
Current Time: Mon Jul 21 00:17:01 EDT 2025
Powered by FUDForum. Page generated in 0.03338 seconds
