Home » Newcomers » Newcomers » How to solve this problem?(I open eclipse and see that it was blank.I cannot open the new Java project.It shows a big cross symbol and state that failed to create the part's control)
How to solve this problem? [message #1839479] Mon, 22 March 2021 06:53 Go to next message
java.lang.NegativeArraySizeException: -966927305
at org.eclipse.swt.program.Program.getKeyValue(Program.java:164)
at org.eclipse.swt.program.Program.getProgram(Program.java:196)
at org.eclipse.swt.program.Program.getPrograms(Program.java:228)
at org.eclipse.ui.internal.registry.EditorRegistry.getSortedEditorsFromOS(EditorRegistry.java:462)
at org.eclipse.ui.internal.registry.EditorRegistry.addExternalEditorsToEditorMap(EditorRegistry.java:302)
at org.eclipse.ui.internal.registry.EditorRegistry.initializeFromStorage(EditorRegistry.java:578)
at org.eclipse.ui.internal.registry.EditorRegistry.<init>(EditorRegistry.java:183)
at org.eclipse.ui.internal.WorkbenchPlugin$15.compute(WorkbenchPlugin.java:1366)
at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:70)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:271)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:237)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:608)
at org.eclipse.ui.internal.WorkbenchPlugin.getEditorRegistry(WorkbenchPlugin.java:464)
at org.eclipse.ui.internal.Workbench.getEditorRegistry(Workbench.java:1499)
at org.eclipse.jdt.internal.ui.viewsupport.AppearanceAwareLabelProvider.<init>(AppearanceAwareLabelProvider.java:51)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerLabelProvider.<init>(PackageExplorerLabelProvider.java:55)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.createLabelProvider(PackageExplorerPart.java:654)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.setProviders(PackageExplorerPart.java:601)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart.createPartControl(PackageExplorerPart.java:500)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:158)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityView.createPartControl(CompatibilityView.java:155)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:365)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:64)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:999)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:964)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:405)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:332)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:999)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run(PartRenderingEngine.java:544)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:528)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:73)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:765)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:730)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:714)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:109)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4742)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:119)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:677)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:71)
at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:150)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:673)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:51)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:82)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.lambda$0(LazyStackRenderer.java:83)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:152)
at org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(PerspectiveStackImpl.java:1)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(WorkbenchPage.java:4035)
at org.eclipse.ui.internal.WorkbenchPage.lambda$10(WorkbenchPage.java:3972)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3972)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:96)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:83)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1469)
at org.eclipse.ui.internal.StandardTrim.createStatusLine(StandardTrim.java:118)
at org.eclipse.ui.internal.StandardTrim.createWidget(StandardTrim.java:48)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:346)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:227)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:94)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:37)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolControlRenderer.createWidget(ToolControlRenderer.java:129)
at org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(TrimBarRenderer.java:109)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:688)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1083)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
at org.eclipse.equinox.launcher.Main.run(Main.java:1461)
Re: How to solve this problem? [message #1839484 is a reply to message #1839479] Mon, 22 March 2021 09:05 Go to previous messageGo to next message
This needs some context, and might work better as a bug report in bugs.eclipse.org. That would include what release of Eclipse
this is, and on what platform, because it looks like an issue interacting with the file association support on that platform.
Re: How to solve this problem? [message #1839487 is a reply to message #1839484] Mon, 22 March 2021 09:44 Go to previous messageGo to next message
My platform is windows
Re: How to solve this problem? [message #1839502 is a reply to message #1839487] Mon, 22 March 2021 21:05 Go to previous message
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=IDE
Previous Topic:Eclipse crashes on any git operation
Next Topic:Unable to add Eclipse C/C++ to windows ALL APP menu
Current Time: Mon Jul 21 13:50:56 EDT 2025
Powered by FUDForum. Page generated in 0.28593 seconds
