Eclipse crashes on any git operation [message #1839480] |
Mon, 22 March 2021 07:24  |
Hi all,
I cannot do any git operation anymore, and get the following error:
(Eclipse:4186): GLib-GIO-CRITICAL **: 12:01:53.767: g_dbus_proxy_get_object_path: assertion 'G_IS_DBUS_PROXY (proxy)' failed
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007eff9ca87660, pid=4186, tid=18671
# JRE version: OpenJDK Runtime Environment (11.0.10+9) (build 11.0.10+9-Ubuntu-0ubuntu1.18.04)
# Java VM: OpenJDK 64-Bit Server VM (11.0.10+9-Ubuntu-0ubuntu1.18.04, mixed mode, sharing, tiered, compressed oops, g1 gc, linux-amd64)
# Problematic frame:
# C [libglib-2.0.so.0+0x3b660] g_str_hash+0x0
# Core dump will be written. Default location: Core dumps may be processed with "/usr/share/apport/apport %p %s %c %d %P %E" (or dumping to /jytoussd/progs/eclipse/core.4186)
# An error report file with more information is saved as:
# /jytoussd/progs/eclipse/hs_err_pid4186.log
# If you would like to submit a bug report, please visit:
# https://bugs.launchpad.net/ubuntu/+source/openjdk-lts
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
This happens the moment I click OK to submit my git credentials.
Eclipse is updated regularly, currently:
Version: 2021-03 (4.19.0)
Build id: 20210312-0638
Git on the command line runs fine.
This has only happened recently, probably after an update. I'm also attaching the error report file which clearly shows the crash happens in sshd.
Any ideas how I can fix this?
JY.
FUDForum. Page generated in 0.09079 seconds
