Home » Modeling » TMF (Xtext) » How to get xtext comment information?
How to get xtext comment information? [message #1839353] Fri, 19 March 2021 09:24 Go to next message
I want to preserve the comments in my dsl and change the comments like python's grammar.
such as:
In my dsl:
// comments
/* comments */ A = B /* comments */;
generated python code:
// comments
''' comments ''' A = B /* comments */
If I define a new comment rule like
Comment: /* (name+=Any_Other)* */
, I cannot figure out a way to put the rule in my grammar. ( I have to restrict the place where comment can exist! )
Is there a simple way to achieve this?
Re: How to get xtext comment information? [message #1839354 is a reply to message #1839353] Fri, 19 March 2021 09:26 Go to previous messageGo to next message
you need to access the node model and traverce it. NodeModelUtils might be a starting point.
Re: How to get xtext comment information? [message #1839366 is a reply to message #1839354] Fri, 19 March 2021 10:19 Go to previous messageGo to next message
I have looked through some information in the node by debug mode, but I don't know how to get the comment in one node. The function getTokenText will still remove hidden tokens such as whitespace/comments. Is there any way to change the default hidden action for comments?
Re: How to get xtext comment information? [message #1839368 is a reply to message #1839366] Fri, 19 March 2021 10:25 Go to previous messageGo to next message
you can call INode.getText and INode.getPrevious/getNextSibling
you may let you inspire from MultiLineCommentDocumentationProvider
Re: How to get xtext comment information? [message #1839379 is a reply to message #1839368] Fri, 19 March 2021 11:52 Go to previous messageGo to next message
Thank you ! Now I can get text of the nodes. But when it comes to preserve the comments, I wonder where should I use these nodes and comments.
For example, in my xtend file I define compile functions to translate my rules to python. In these functions I can get nodes and then get the comments. But I still need to know the location of comments. Otherwise it cannot handle code such as
/**/ A /**/ = B;
My compile function is like this:
private def compile(AbstractElement e) {
    	var ret = new String;
    	/*Where should I get and add the comments to the return string?*/
    	if(...) {
    		ret += '''«e.a.compile»'''
    	else
    		ret += '''«e.b.compile»'''
        return ret;
Re: How to get xtext comment information? [message #1839385 is a reply to message #1839379] Fri, 19 March 2021 12:28 Go to previous messageGo to next message
use the node of your objects or features of object as starting point (see nodeModelUtils)
Re: How to get xtext comment information? [message #1839392 is a reply to message #1839385] Fri, 19 March 2021 14:39 Go to previous messageGo to next message
You might find that https://git.eclipse.org/r/plugins/gitiles/ocl/org.eclipse.ocl/+/refs/heads/master/examples/org.eclipse.ocl.examples.xtext.idioms/src/org/eclipse/ocl/examples/xtext/idioms/serializer/IdiomsCommentSegmentSupport.java gives you some ideas.
Ed Willink
Re: How to get xtext comment information? [message #1839405 is a reply to message #1839385] Sat, 20 March 2021 02:08 Go to previous messageGo to next message
Do you mean I have to generate comments like this:
    	if(findcomment()) { ret +=  commentStirng; }
        return ret;
Re: How to get xtext comment information? [message #1839406 is a reply to message #1839405] Sat, 20 March 2021 02:20 Go to previous messageGo to next message
Besides the very inconvenient use of
Xtend Rich strings more or less yes
Re: How to get xtext comment information? [message #1839414 is a reply to message #1839406] Sat, 20 March 2021 09:20 Go to previous message
Note that the Xtext philosophy is that comments are transient, i.e. they are converted from source text to the node model but are not incorporated in the final AS model, so if you save the AS model and reload and serialize back to text the comments are lost.
If you care enough about comments to extract them from the node model, you should perhaps make them first class rather than hidden components of your grammar. This will avoid all need to recover comments from the node model but will incur a bot of a fight to support comments everywhere, which isn't always that sensible, so supporting only sensible comments may be adequate.
In Java, who really wants to be able to type
import/*this is an import*/ java// This is the system package
./*separated from*/lang./*and now the real class*/String;
(Both Xtext and Java get this perversion right!).
Ed Willink
Previous Topic:Xtext 2.14 - programmatic EMF model manipulation with minimal re-indexing
Next Topic:Not valid for cross reference
Current Time: Sun Nov 02 23:46:05 EST 2025
Powered by FUDForum. Page generated in 0.05885 seconds
