Home » Eclipse Projects » Eclipse Platform » Eclipse 2021-03RC1 Question/Problem(Upgrading to 2021-03)
Eclipse 2021-03RC1 Question/Problem [message #1838925] Tue, 09 March 2021 11:54 Go to next message
I have a internationalized Eclipse RCP app that I tried upgrading to Eclipse 2021-03RC1 target. On the upgrading, it no longer launches and produces this partial stack trace:
	at java.base/java.util.Optional.orElseGet(Optional.java:369)
	at org.eclipse.osgi.internal.loader.buddy.GlobalPolicy.loadResource(GlobalPolicy.java:66)
	at org.eclipse.osgi.internal.loader.buddy.PolicyHandler.doBuddyResourceLoading(PolicyHandler.java:171)
	at org.eclipse.osgi.internal.loader.BundleLoader.findResource(BundleLoader.java:685)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.getResource(ModuleClassLoader.java:216)
	at java.base/java.lang.ClassLoader.getResourceAsStream(ClassLoader.java:1736)
	at org.eclipse.osgi.util.NLS.load(NLS.java:332)
	at org.eclipse.osgi.util.NLS.initializeMessages(NLS.java:152)
	at XXX.Messages.<clinit>(Messages.java:1538)
The plugin it failed to load has a global BuddyPolicy:
Eclipse-BuddyPolicy: global
The issues seems to occur when it is trying to load variants of the various translation files (for example en_US), which don't exist (we only have en).
I think I tracked down the issue to this function in the GlobalPolicy class:
public URL loadResource(String name) {
	return getExportingBundles(BundleLoader.getResourcePackageName(name)) //
			.stream().findFirst().map(b -> {
				return b.getResource(name);
			}).orElseGet(null);
This:
getExportingBundles(BundleLoader.getResourcePackageName(name)).stream().findFirst()
returns an optional that has no value. I think when it tries to execute "map" it is failing.
This was on RC1, so it might be something that's already been fixed or perhaps I need to change something on my side. Any thoughts would be appreciated.
Emily
Re: Eclipse 2021-03RC1 Question/Problem [message #1839148 is a reply to message #1838925] Mon, 15 March 2021 17:45 Go to previous messageGo to next message
Maybe this has been caused by changes introduced for https://bugs.eclipse.org/bugs/show_bug.cgi?id=570394 in https://git.eclipse.org/c/equinox/rt.equinox.framework.git/diff/bundles/org.eclipse.osgi/container/src/org/eclipse/osgi/internal/loader/buddy/GlobalPolicy.java?id=bf36b48391737e1d37a4e0aca0f0b1f7832fc103 ?
Re: Eclipse 2021-03RC1 Question/Problem [message #1839179 is a reply to message #1839148] Tue, 16 March 2021 18:40 Go to previous messageGo to next message
Yup, thanks for passing this along. Look likes it been fixed too so I'll checkout the new build. Thanks!
Re: Eclipse 2021-03RC1 Question/Problem [message #1839440 is a reply to message #1839179] Sun, 21 March 2021 11:38 Go to previous message
Looks like the problem made it into the 4.19 release.
I see a fix for bug 571990 in the git repo, but the problem occurs with my target platform pointing to the 2021-03 software site.
Previous Topic:Add Entry to Theme drop down menu
Next Topic:[Help] (SWT:5152): Gtk-WARNING ?
Current Time: Mon Jul 21 09:11:45 EDT 2025
Powered by FUDForum. Page generated in 0.06298 seconds
